Waist trim, "buttons", door, window seal
There have been a few posts on this topic but they don't quite answer my question (in fact there seem to be multiple answers due to variations in peoples' cars).
The drawing shows a cross-section of the door. Paul Matty supplied new "button" rivets and seals. I'm guessing that the rivet goes on as shown and the trim clips on. But what about the seal? It has holes that line up with the rivet holes ... but the rivet doesn't seem nearly long enough to go though both the body and the rubberseal. (Yes, there is a build up of new primer & paint but it can't be enough to make that much difference).
Experience / knowledge please!
Keith
Keith
- kcrossle
Keith,
There is a strip of thin metal that's part of the window frame between the glass and the rubber seal. I used a clip nut over this with a self tapper to hold the whole lot together. You might have to grind the screw to the correct length to stop it touching the glass.
- elanman999
Thanks to you both - I think we have it. John's answer puzzled me a while which drove some more research that David just confirmed. I talked to Andy at Spyder who clarified it for me - the supplied clip / rivet is an MG item and is too short. As you say, make it not a rivet anymore and screw it in.
Easier than drilling it out - put it in a socket and give it a tap with a hammer. Remember that for next time :-)
Will update later as we progress. Thanks!
Keith
Keith
- kcrossle
