Stubborn wiper nut
PostPost by: RichardS » Sat Jul 19, 2008 10:46 am
Any tips on removing the stubborn chrome nuts from the wiper shaft?
I've tried penetrating oil but the nuts are stuck fast. I can get a reasonable grip on the wiper wheel boxes [as the dash is out] to stop them moving but reasonable [and extreme!] force with a ring spanner on the nut is not having any effect.
wiper.jpg and
Lotus Elan Sprint FHC 1973
RichardS
PostPost by: John Larkin » Sat Jul 19, 2008 11:12 am
1967 S3SE FHC, 1974 Rover P6B, 1949 Lancia Aprilia
John Larkin
PostPost by: garyeanderson » Sat Jul 19, 2008 11:12 am
Hi Richard
Most come off easilly some are stubborn (fused, dis-similar metal) as yours appears to be. After waisting an hour or so and not getting anywhere I resort to a hack saw or wiz wheel and just replace it as its not worth the time. Its tough to put any sort of heat into it without damaging the fiberglass. Did you try to tighten it first?
Gary
garyeanderson
PostPost by: nebogipfel » Sat Jul 19, 2008 12:21 pm
Yes cut them off and fit new ones, they're cheap enough
nebogipfel
PostPost by: RichardS » Sat Jul 19, 2008 2:31 pm
Is the thread that the nut screws onto attached to the wheel box? I am a bit concerned I might damage the thread as I attack the nut with a hacksaw! Is it just a case of being very careful?
RichardS
PostPost by: garyeanderson » Sat Jul 19, 2008 2:42 pm
The hole unit is junk get a new one. If you were to get the nut off the threads come off with the nut.
garyeanderson
PostPost by: RichardS » Sat Jul 19, 2008 3:36 pm
Gary
The picture of the assembly is not very informative in my workshop manual. Will I have to replace the whole wiper wheel box [these are quite expensive at at ?50 a pair altho in the scheme of things a minor expense!] or would I just need the wiper bezel kit?
RichardS
PostPost by: garyeanderson » Sat Jul 19, 2008 4:06 pm
I don't know the reason that you are trying to remove it. If its broken then it needs to come off without damaging the fiberglass around it (not adding to the stress cracks) Generally the only other reason to pull them off it to paint the Elan, if your worried about ?50 now, put it back together and sell it. It only gets worse.
Gary
garyeanderson
PostPost by: RichardS » Sat Jul 19, 2008 4:36 pm
Gary
Thet need to come off for a respray. It looks as though I will have to get the hacksaw out. I don't think I'll sell up just yet!
RichardS
PostPost by: HardTop » Sun Jul 20, 2008 10:49 am
no real lotus owner spends money unless absolutely neccessary, you need it for thr other cases.
Try a nut spliter one may just fit. it may need adjusting with a grinder
This would exert no load on the body shell
Dremel cutting disk but you would only be able to weaken the nut because you don't wish to damage the threaded shaft. You would need to be very careful it doesn't skid off onto the shell
Perseverance and patience
HardTop
First Gear
First Gear
PostPost by: RichardS » Sun Jul 20, 2008 3:50 pm
HardTop wrote:no real lotus owner spends money unless absolutely neccessary, you need it for thr other cases.
Good idea - I found this which may do the trick. http://www.frost.co.uk/item_Detail.asp? ... gineToolsI agree with your sentiments - although I am not restoring to totally original it is nice to keep as many of the old bits as possible and practical.
RichardS
PostPost by: alexblack13 » Mon Jul 21, 2008 9:27 pm
Hi Richard,
No one near you can borrow a nut splitter from? I will lend you one if need be...
I would carefully use a junior hack. Nip off one of the corners of the nut. You will no doubt just 'graze' the threads on the box but if it is just a little damage it will not matter at all. Just clean up the threads (Thread file?) carefully 'till a new nut will run down them without prob's. you should get away with this no bother. Give the system a good clean and check whilst it is out. Best to replace any suspect bits now whilst easy to do. Bugger of a job on complete car!! :shock:
Good luck either way. Let me know if you need a splitter sending down.
Alex B 8)
Alex Black.
Now Sprintless!!
alexblack13
PostPost by: RichardS » Tue Jul 22, 2008 7:22 pm
Thanks Alex
Yes _ I thought as well as removing for the respray I can see that it is much easier to check and service the wiper bits now rther than when everything is back.
Thanks for the offer of the nut splitter - there are some on Ebay for a fiver so I might as well buy one! Looks the neatest solution for finishing off the pesky nuts.
Richard.
RichardS
PostPost by: robcall » Wed Jul 23, 2008 8:01 am
Took mine out today-not something you really want to force.
Like Richard I had one stuck fast -but tightening/loosening the nut managed to free It.
Now-getting the passenger washer nozzle out (and back in) without removing the dash :roll:
Nigel Robertson
robcall
PostPost by: RichardS » Wed Jul 23, 2008 1:08 pm
robcall wrote:Now-getting the passenger washer nozzle out (and back in) without removing the dash :roll:
That was the easy bit for me - but I have the dash half out!!
Have bought a nut splitter on Ebay so will report back if it works.
RichardS
Next
