Bonnet Catches
So I put the bonnet catches on the firewall and the pull cables in. Double nuts and Loctite to make sure they won't come loose.
As I put the bonnet on, I realized there should be some type of bracket on the underside of the bonnet itself that engages the catch.
I have holes for these brackets, but no brackets.
Could someone be kind enough to post a picture of this area? I don't mean to be picky, but if someone in Europe could post it I could check it while eating breakfast tomorrow
'66 Lotus Elan S2 Roadster RHD
- DJThom
Hi DJ Thom, what's for brekky?
Being a cheapskate and too impatient to wait for parts to be posted, I made my own from stainless.
I started to copy the tophat shape and position of the bracket from the old bonnet to the new, but the cutouts were different, so I started from scratch and tried to make a more robust version, that's why there are several holes(!)... but found that adjustment was easier with a smaller final version.
I ended up sitting in the engine bay, without the engine but with a pair of pliers ... a little bend here and a little bend there. I now have a satisfying shutting action. If I could put up with the cable trawling across the cam cover I'd have a nice opening action too, but I cant, so it's attached to the bulkhead and the bonnet needs a tap to open.
This is probably of no use to you at all as I've just noticed yours is an S2.
I'll add my usual caveat that says this may or may not be original but it works for me. Have a nice time.
SADLOTUS - Fourth Gear
here is an other shot, it's my Sprint's catch but as far as I am aware they are the same as S2
SADLOTUS wrote:........If I could put up with the cable trawling across the cam cover I'd have a nice opening action too, but I cant, so it's attached to the bulkhead and the bonnet needs a tap to open........
I made a stand off bracket to hold the cable off the cam cover. I think it's preferable to have a gentle curve in the cable for a smooth action
DJ, I presume on a S2 you have two cables and two release pulls - so this point doesn't apply anyway.
nebogipfel wrote:[quote="
lotus did fit a cable bracket on the Sprint although it may have been on other cars?
On my S2, one side has a strip of fiberglass about an inch wide bonded into place across the gap (bonding loose at one end, I now notice). That strip is wrapped with thin aluminum sheet. On the other side, a similar strip of something is held in by two sheet metal screws that are in the sides of the gap. Don't know which side is original. The release cables are behind the dash on the S2, not in the engine bay. Should be able to get a photo later today if it is of interest.
Andrew Bodge
'66 Elan S2 26/4869
'66 Elan S2 26/4869
RotoFlexible - Fourth Gear
The fiberglass bridge between is wrapped with a small piece of metal as shown in the photos of the S2 bonnet.
From what I can remember, my old S2 was the same as my Sprint. See picture.
But when I look at the Brian Buckland manual it appears I am wrong as the S1 & S2 bonnets did not have metal inserts ? simply fibreglass.
S3 version was the same but with a strip of stainless steel wrapped around the fibreglass.
S4 onwards were as per the picture.
Clearly later cars with metal inserts were to overcome wear problems.
But as you can see from other pictures, it is not beyond you simulating a latch. If you want originality ? then you will have to fibreglass across the gap and then cut-out the aperture.
Brian Clarke
(1972 Sprint)
Brian Clarke
(1972 Sprint)
bcmc33 - Coveted Fifth Gear
I don't have the Buckland book, All of the S2, and S3 bonnets that I have seen were wrapped with metal. The S4 was the bridge piece of metal that was rivited on like the Photo that Brian posted (yellow bonnet).
