Where's the Back Seat?
elans3 wrote:all baby elan seats were of the fixed type.
This is not the case, from the cars I have seen up until the Sprint the seats did tilt up, sometime around the introduction of the Sprint Lotus then fitted a bracket to secure the seats. I use this as an indication that a car is a genuine Sprint as I have never seen a non Sprint with these brackets.
Lotus may have fitted these brackets to export cars or just to Federal spec cars but I am not sure, I'm sure someone will correct me.
My S2 seats do tilt but my Sprints did not, well they do now as I removed the brackets as it makes access to the rear better.
Below is a pic of the Sprint seat securing brackets I removed.
mopho wrote:Drilled through the floor and then bolted the mounting brackets with large washers underneath to spread the load. I had four point belts before and this is much better
Ah, thanks, that explains it!
'68 S4 Elan SE DHC ~ S1 Elise 111S ~ 2-11 GT4
- Schrodinger
My car is a Sprint and doesn't have the tracks. That doesn't mean the PO didn't remove them. I will check and see if there are holes in the floor pan.
Does anyone in the US have a set of brackets they don't want anymore?
Tom
tbsmith - Second Gear
Users browsing this forum: bitsobrits and 35 guests
