Easy Boot Lid Seal question
PostPost by: stuartgb100 » Sat Aug 05, 2006 5:29 pm
Water is leaking badly into the boot.
There definitely is a leak (minor) from the rear screen rubber, but 90% + is coming via the boot lid seal.
I've bought a new seal, but before I fit it, which way round does it go?
The flap that seals against the lid could either be pointing in towards the boot area, or outwards.....?
Since the PO fitted the seal with the join under the windscreen, I'm not inclined to just copy his installation.
Stuart.
stuartgb100
PostPost by: schroeder » Sat Aug 05, 2006 7:15 pm
Stuart
Mine has no such flap but my vote is outwards and make the join in the center above the rear bumper
Stu
schroeder
PostPost by: stuartgb100 » Sun Aug 06, 2006 5:24 am
Stu,
When you look end-on at a new seal, it is like an ' h ' in section, except that the top leg of the ' h ' is inclined, like ' / ' ... (that's what I meant by 'flap') ... so there are two ways to fit it.
If there are two ways to fit it, then I would guess that only one way is correct ?
Stuart.
stuartgb100
PostPost by: john.p.clegg » Sun Aug 06, 2006 9:36 am
No saying it's correct but on mine the / of the h is pointing away from the boot....
John :wink:
PostPost by: schroeder » Sun Aug 06, 2006 11:06 am
Stuart
The / should be pointing out of the boot as John suggests. That way any pressure, such as driving wind, will increase the seal to the lid. If it is fitted facing toward the boot then the pressure will force water between the lid and the seal.
Stu
schroeder
PostPost by: stuartgb100 » Sun Aug 06, 2006 1:48 pm
Thanks to you both. Right, off to give it a try.
Stuart.
stuartgb100
Users browsing this forum: No registered users and 43 guests
