Front Valance Seam
I have a seam running on the underside of the front valance of my early +2. It's just visible in the attached picture. Is this normal, or the result of someone adding a new front end? The seam appears to join the lower valance with the rest of the body. The outer joint is very poor with a gap between the body and valance seams. Internally the joint is seamless.
I?d be interested to know if this is a feature of all vehicles and do I therefore need to remove or repair?
Kevin
More pictures at:
www.lotuselan.info
Kevin
More pictures at:
www.lotuselan.info
- kevin
I had the car up yesterday to fix the exhaust, and when I moved the axle stand away from the front member of the Spyder frame, I left it RIGHT UNDER the front seam before ensuing the lowering with the trolley jack... I stopped when I heard a hint of crunching and VERY quickly jacked up....... THANK GOD..
Moral: NEVER lower a jack too fast.... (ehm., and watch where you put things.)
- thor
