Rear seat belts
Kev,
If yours is a late model, the mountings will be there but will be behind the edges of the trim panels. The Workshop Manual (Body - B.31) explains what holes need to be cut in the trim when installing the mountings, or if they've never been used.
PM me your e-mail address and I can send you some photos of installed lap belts showing the mountings - I've recently taken some for information for someone else.
Kind regards,
Matthew
Kind regards,
Matthew
- ppnelan
Kev,
I understand. Section B.31 in 'the Manual' explains how to fit the plates, cut the trim, and fit the lap belts. For the inner one (in the transmission tunnel) you'll need access (and a helper!) under the car - do you have use of an inspection pit?! The outer one goes on the inside of the wheelarch so should be easier to fit.
Have fun!
Matthew
Have fun!
Matthew
- ppnelan
