Wiper Spindles
Just bought new rubber, cowl and nut for the wiper spindles.
The nuts wont grip the thread with the rubbers in place. Without the rubber its fine
Anybody else had this problem?
"lets look on it as an investment darling. One day it will..................................."
hat - First Gear
I had the same problem when I reinforced this area from inside the car to repair the original spindle holes - thus increasing the thickness of the bodywork.
There's a black plastic spacer underneath where the spindles poke through the body. If you can poke the spindles back through into the car you should be able to remove the spacers and cut off a couple of mm with a hacksaw, allowing a bit more thread for the nuts to grip (easy for me to say as the dash is currently out of my car..)
Good luck!
Good luck!
simon.mitchell - Second Gear
