Vacuum Pod Spring
Hi there,
Anyone tell me which hole on the headlight assembly the vacuum pod spring bolts in. ie the one at the top near the micro switch or the lower one. If the lower one there seems to be a lot of pressure on the spring to overcome with a vacuum. Is this right
thanks in advanve
thanks in advanve
Mark,
Just had a look at my Sprint and the spring/vac rod are in the 2nd hole (lower) i.e. the one further AWAY from the micro switch. Headlights pods work fine.
Mark - I just got a new spring for the headlights and it's so much stronger than my old one that I put it in the second(lower) hole. I had the old one in the upper hole and it still didn't lift the pods properly
Paul
65 S2 (with headlights converted to Failsafe!)
Paul
- brassringfarm
