Extra holes behind the tail lights?
Emma-Knight wrote::idea: By size and position original 2x2 tail lamp setup S1 style replaced by Vauxhall cluster S2 style. The small hole for the outer lamp probably disapeared in the outer big hole.
The size of the small S1 hole is the same as the front indicator hole and fixings.
Anna
Yes, it could well be!
Mazzini - Coveted Fifth Gear
Sorry to flog a dead horse (that's English for continuing a dead topic) but the big holes would not have been for the S1 lamps, which have small mounting holes, and they also have the wrong spacing; but the small holes are in the exact position (and pattern) for the S1's main/brake lamps if its flasher lamps were in the centre of the large outer holes.
The large holes are in the exact position for the Vauxhall unit's bulb holders relative to the square of small bolt holes which attach it. So Zog's early S2 simply had Vauxhall lamps substituted for its original Lucas units.
Meg
So I got out some Simple Green and a tooth brush and cleaned the spot on the firewall where the body number is placed. Although the chassis number on this car is 4212, the body number is 3837. I've read where they often don't match. I'm guessing this body was tucked in the corner of the factory storage yard for a while and when they went to use it they had to change the holes for the Vauxhall tail lights.
For reference, the car has the full width one piece dash, the round oil filler cap and the round screw on fuel filler cap.
Fun detail stuff. Thanks for all the input!
- zog
Mine too.
Only early S1s had matching body numbers.
I used to have simple round oil and petrol caps too but they all found new lives long ago. Kelvedon supplied a later 3-eared oil cap which you can actually grip and after losing two petrol caps after forgetting to refit them I bought a locking cap and put its key on the ignition's ring. Ironically, I started detaching the ignition key during petrol fills (to hold the immobiler off) and a couple of weeks ago lost the cap with all my other keys on a roundabout! By the time I found it, in the middle of two busy lanes, it had been run over but I straightened it out and had a spare petrol key at home as that had broken.
Meg
