New Plus 2 body shell
The main difference with the screen aperture is there is no lip for the rubber along the bottom on those designed for bonded screens, the dash top support is moulded in such a way that it does away with the lip, or at least it is on my car. A bit difficult to explain & I'm not sure I can get a photo without removing the crash pad, which I don't really want to do. As I understood things, apart from the very first cars, the screen is the same on all models, sourced from the Ford Consul Capri, but the aperture changed depending on how it was fitted. (At least two different types of rubber, plus bonded) ?
As mentioned earlier by Randy, there are several other differences, probably the most difficult bit to change is the boot floor, which is totally different for the transverse silencer. Of course, if you weren't worried about originality, you could just use the later style shell as is, or just change the easy bits, but I've seen the shells offered by this ebay seller, http://www.ebay.co.uk/itm/lotus-elan-bo ... xyuR5TZ4Nx, if it's the one you refer to. They do need a hell of a lot of remedial work & are very thin so need a lot of reinforcing. You will have nearly as much work to get one ready for paint as you would to repair your original shell.
It's fibreglass, you can with a little practice & patience
As Rohan says, much of the work is not that difficult, with a little guidance from your uncle, you could do it yourself, then just leave the final finishing & painting to a professional.
Regards, Tim
ClashofLotus wrote: reading Tims story makes me think I can repair anything!!
Regards, Tim
- Orsom Weels
Orsom Weels wrote: A bit difficult to explain & I'm not sure I can get a photo without removing the crash pad, which I don't really want to do.
They're not very good, but here are a couple of pic's which I hope show what I was trying to describe.
- Orsom Weels
Hey guys,
Sorry for not replying to you all sooner but thanks so much for the information.
I am still looking for a good donor body before I commit to fixing mine - my last resort will be to buy a new body and put in the time to fix that up to spec. Im not really that fussed about originality as the current nose on the car is actually from a +2S even though mine is a fairly early +2.
Special thanks to Tim for taking the photos too! Much appreciated.
Will let everyone know how I go and if anyone hears of a good donor body (especially in Aus) please let me know.
Adam
Adam
ClashofLotus - First Gear
