Breaking Down the subject of Paintwork
Just to throw something else in the ring, I had my shell stripped with 'K2'. Potassium I was told. The fellow who did the work gave me the option of soda or K2, with the soda being about 2-3 times the price. The result was pretty good, a bit rough to the touch, but it didnt seem to erode the gel. I haven't experienced a soda blasted shell so I can't say if the savings were worth it. The fellow did vettes with it that he restored. As for leaving old paint it seems like a gamble unless you know for sure what it is. be a shame to put in all that work and have the new paint react.
Scott
69 dhc
69 dhc
- scottlong1
Bit late but from the K2 brochure-
These same tests also conclude that “K2-STRIP” will leave a slightly increased profile without pitting the metal. Although not recommended for use on fiberglass, plastic, aluminum or other soft substrates, this new media will allow for a significant reduction in the time required to remove coating off metals.
- Jayson42
A thread from the past, but relevant to me. I am faced with stripping the paint of my Sprint.
I am a big fan of mechanical help, and soda blasting was going to be my method of choice. I have however recently visited Option 1 (seats retrimmed), and Spyder (new stainless ladder frames) and both advised against soda blasting. I knew that Option 1 had always been an advocate of scraping the paint off, but I had understood that Spyder used blasting. Spyder said they have changed their approach as the rectification required after blasting was greater than the time taken to scrape the paint off manually.
I guess I will be sharpening my chisels.
On the subject of warming the body to encourage drying out, I have just purchased a couple of these:
https://www.networldsports.co.uk/harrier-rounded-standing-patio-heater.html
Its not going to rival a heated spray booth at a bodyshop, but I would imagine that a booth at a bodyshop is in high demand, whereas I can afford to leave the car for longer periods being warmed. If the idea doesn't work, I can always use them on my terrace.
32 Standard 12
Various modern stuff
32 Standard 12
- Andy8421
When I was working I saw soda blast used to remove paint/ink from a coke can. Very impressive!
My experience of blast cleaning in general is that the combination of media, pressure, and distance from the work piece can make a huge difference.
Having helped a friend strip his car I decided to pay.
Richard Hawkins
Richard Hawkins
- RichardHawkins
