Door Locks
PostPost by: types26/36 » Tue Dec 19, 2006 10:32 pm
bcmc33 wrote:From memory, my old S2 had the locking device built into the handle.
That is not quite correct, the S2 outside handle is bolted to the door and is a compleatly seperate unit from the the lock/barrel/mechanism/inside lever which is an all in one unit with the push button with key slot protruding through the outside handle.
It is nothing like the S3 or S4 handles.
types26/36
PostPost by: RotoFlexible » Tue Dec 19, 2006 10:51 pm
bcmc33 wrote:A picture, a picture, for Ch***t sake, a picture.
Brian Clarke
Here are pictures of S2 door handles from the outside. The left-side barrel is missing - in the closeup, you can see the slot that retains the barrel in the sleeve, and the hole at the back of the sleeve that the actuating rod at the back of the barrel goes through (I think). What I am calling the "sleeve" is the same as the bit that was outlined in the photo a few posts back.
rhs_door_handle.JPG and
Right-hand door handle, button intact.
lhs_door_closeup.JPG and
Close-up of missing button, note slot and hole at back of sleeve.
lhs_door_no_button.JPG and
View of left-hand door handle, S2. Note missing button.
Andrew Bodge
'66 Elan S2 26/4869
RotoFlexible
PostPost by: types26/36 » Tue Dec 19, 2006 11:02 pm
Andrew,
The barrel that is missing is not part of the outside handle (shown in your pic) it is part of the compleat inside mechanism. Well it is with my S2 and my chassis number is reasonably close to yours 26/3944
types26/36
PostPost by: RotoFlexible » Wed Dec 20, 2006 2:55 am
types26/36/74 wrote:Andrew,
Exactly. The exterior handle fits over the sleeve (best seen in the close-up) and the barrel protrudes through the handle, but the sleeve and the barrel (with lock tumblers inside) are part of the inside mechanism. RD Enterprises website has a nice picture of a reproduction door handle - if only he carried the lock mechanisms as well!
Andrew Bodge
'66 Elan S2 26/4869
RotoFlexible
PostPost by: bcmc33 » Thu Jan 04, 2007 3:53 pm
bcmc33
PostPost by: DJThom » Sun Jan 07, 2007 4:22 am
Thanks for the tip. We should place bets on what the final price will be. My guess is around 400 pounds based on the last pair I saw go for around 400USD each. :(
No luck finding parts from a donor car yet either. Mind you, with the copius quantities of turkey being consumed lately, I have not been that diligent in my search.
Thankfully on the S2 it's not too hard to reach in and use the interior handle to open the door since pressing the barrel in renders mine impossibly jammed...
DJThom
PostPost by: bcmc33 » Sun Jan 07, 2007 10:44 am
Darren,
I've just noticed, looking at the eBay locks again, that they are non-locking - so I guess the barrel sleeve will be blind.
What Lotus Elan were they off then?
There's a LH lock on eBay http://cgi.ebay.co.uk/LOTUS-ELAN-DOOR-L ... dZViewItem
I know this is the wrong side for you, but I'm sure the barrel will be common, and could be switched.
Brian Clarke
bcmc33
PostPost by: RotoFlexible » Sun Jan 07, 2007 10:06 pm
bcmc33 wrote:I've just noticed, looking at the eBay locks again, that they are non-locking - so I guess the barrel sleeve will be blind.
Brian Clarke
Probably off the rear doors of the donor car from which they were scavanged...? This seller seems to keep coming up with them.
Andrew Bodge
'66 Elan S2 26/4869
RotoFlexible
PostPost by: bcmc33 » Fri Jan 12, 2007 4:08 pm
Darren,
Here's another one for you.
http://cgi.ebay.co.uk/LOTUS-R-HAND-DOOR ... dZViewItem
Brian Clarke
bcmc33
PostPost by: worzel » Fri Jan 12, 2007 9:20 pm
Just to repeat a reply I made earlier.
It's possible top fit radial pin tumbler barrels into these locks. They're made by a firm called HYKEE. They are thief proof and require no mods to the door or handle. Made of brass they are vastly superior to the originals and a damned sight cheaper. The firm supplies countless locks of this type for a huge range of classic cars.
worzel
PostPost by: SADLOTUS » Tue Jan 23, 2007 10:17 pm
Just seen this:
1 x Nos S1/2 drivers side door catch/lock with key ?
very scarce ?50
don't know if it's still available.
www.historicparts.co.uk
click on workshop clearout
or Google: Ref RC/6/7/06 LOTUS ELAN PARTS
SADLOTUS
PostPost by: RotoFlexible » Wed Feb 21, 2007 2:13 pm
Just lost another lock to a sniper :cry: . This is three or four now - I've lost count. I just hope these locks are going onto cars and not onto shelves as investments. Guess I'm going to have to up my maximum next time a good one comes along.
Andrew Bodge
'66 Elan S2 26/4869
RotoFlexible
PostPost by: DJThom » Wed Feb 21, 2007 6:02 pm
was it the RHS one on Ebay? I was watching it but forgot to check back before it ended. At least my interior handle works...
DJThom
PostPost by: RotoFlexible » Thu Feb 22, 2007 9:19 pm
DJThom wrote:was it the RHS one on Ebay? I was watching it but forgot to check back before it ended. At least my interior handle works...
Item no. 130078928687. I think it was an LHS mechanism, a little ratty looking, in a lot with a door handle and striker plate from an S3 or S4. Went for 36 GBP.
Andrew Bodge
'66 Elan S2 26/4869
RotoFlexible
PostPost by: bcmc33 » Sat Mar 03, 2007 9:26 pm
Darren,
Don't let these get away - Snipe at 2 seconds.
http://cgi.ebay.co.uk/Lotus-baby-Elan-S ... dZViewItem
Brian Clarke
bcmc33
PreviousNext
Users browsing this forum: Richardsona39 and 12 guests
