Need info, Elans S-2 door seals
PostPost by: Marc Nichols » Mon Oct 31, 2005 3:20 am
:?: Our Elan does not have passenger/driver door seals fitted but I have several different styles of seals in a box. What is the cross section shape of the correct seal and where/how is it applied?
Thanks for the assistance.
Marc
Marc Nichols
New-tral
PostPost by: khamai » Mon Oct 31, 2005 6:59 pm
Marc,
The S2 door seal is sort of a peaked oval/round. I'll attempt to better describe it... Generally oval or round in shape, but has two flats that come to a peak. The angle of the peak is quite large, nearly flat, say 135-150 degrees.
Hope that helps.
It is available from Dave Bean.
Kiyoshi
khamai
PostPost by: Marc Nichols » Tue Nov 01, 2005 2:50 am
Thanks Kiyoshi, I do have that seal. Does it glue to the body or to the door? Body I would expect.
Marc
Marc Nichols
New-tral
PostPost by: brassringfarm » Tue Nov 01, 2005 4:59 pm
Marc-
I glued mine to the door with good contact cement. Got mine from Tingle, but it's identical to Kiyoshi's description. I've never seen one glued to body, but I could be wrong.
Now for my related question: Where do you get the seal at the top of the door next to the windshield post area? I've never seen it available anywhere. What does it look like?
Paul Zimmerman
65 S2
brassringfarm
PostPost by: types26/36 » Tue Nov 01, 2005 6:18 pm
[quote="Marc Nichols"Does it glue to the body or to the door? Body I would expect./quote]
I asked the same questions on lotuselan.net mailing list a few years ago, someone kindly sent me some pics of an original but unfortunately I have deleated them but the seal is glued to the door.
types26/36
PostPost by: Marc Nichols » Wed Nov 02, 2005 3:34 am
Paul, Brian,
Thanks. Now I feel confident where this thing goes. Today, Ken at Dave Bean Eng. also said he would send a pic of a used door which should be the ticket. Pics the last owner took before restoration show what is obviously a wrong solution, a bodge job. Glad i asked.
As to a seal at the top of the door. I can't locate anything on a parts list image I have. It appears that the pie shaped door seal wraps all the way around the top front of the door turning to the rear. I don't see anything else in that area.
Marc
Marc Nichols
New-tral
PostPost by: DJThom » Thu Nov 10, 2005 5:23 pm
For my Elan, I've got most of my rubber from MacGregors. He has had extensive experience in the interior design group at Leyland and had an Elan as well. Try asking him.
http://www.macgregorukcarparts.com/index.html
DJThom
