Elan+2 S/130 1971 parts for sale
Hello all,
I offer up all theses items for sale. They were taken off my road going 1971 Elan+2 S/130 by my very own hands back in 2009 and dry stored in my garage since then. All parts were working correctly at that time.
Four speed gearbox with gear lever, slave cylinder and speedo drive
Radiator with side surrounds
Sway bar/anti roll bar
Radiator fan
Splined front hubs with disks /bolts/top ball joints - no calipers.
Air box and back plate for Weber carbs - damage to one box bolt hole but fixed with larger washer
Front springs
Pair of drive shafts with Rotoflex couplings attached
Handbrake lever
Steering rack with track rod ends and UJ
Propshaft
Chapman struts with disks
Differential
Four branch manifold
Failsafe headlamp conversion bar
Vacuum pod
Vacuum release solenoid
Brake master cylinder
Clutch cylinder
Starter motor,
Alternator
Servo unit
,,,and just in case -
A used Honda Prelude Vtec gearbox off a 1992 model - dry stored since 2005 as only kept as spare.
Four 185 65 14 Toyo Proxes CF2 with approx 5-6mm tread. One has a centre tread puncture - cable clip nail.
All items are in Cardiff.
Radiator fan
Front springs
Handbrake lever
Propshaft
Differential
Vacuum pod
Clutch cylinder
Starter motor,
Alternator
Servo unit
1971 +2S 180/5 Spyder Zetec
- spyzee
Hi Spyzee,
Coincidentally, there are also ashtrays for the doors and dashboard for sale
- Elan+Tjeerd
Hello
How much for the front springs?
Thanks!
Berni
Thanks!
Berni
berni29 - Fourth Gear
Interested in the airbox and backplate.
Current Cars: '72 Elan +2S130/5, '72 Triumph Stag 3.9L, '72 Spitifire Mk IV. Past Cars: '72 Triumph TR6 (supercharged), '70 MG Midget (K-Series + Type 9), '76 Triumph 2500TC, '72 Lotus Elan +2S130/4, '76 Triumph Spitfire 1500.
- shynsy
