Started to sort out the door gaps. Work in progress.
- stevebroad
Interesting !!!!!!!!!!!!
For anyone interested, here is how I am dealing with the door gaps. This may not be the best way of adjusting door gaps but it works for me
Cardboard for the gap.
P40 to fill gap.
A little fettling still required bu getting there.
P40 to fill gap.
- stevebroad
- stevebroad
- stevebroad
stevebroad wrote:I can't keep it secret any longer, here is my proposed paint scheme for the Elan.
I think an Elise would look great with that paint scheme.
StressCraxx wrote:stevebroad wrote:I can't keep it secret any longer, here is my proposed paint scheme for the Elan.
It would certainly hide all those sharp, unchapmanlike, edges
- stevebroad
- stevebroad
For anyone remotely interested in vehicle weight reduction, I have just compared the Elan's glass to polycarbonate. Original glass weighed 18kg, add the rubber seals and it tops out at just over 20kg. Allowing for the front and rear fixings the polycarbonate replacements weigh 5kg, so around 15kg saving.
- stevebroad
stevebroad wrote:For anyone remotely interested in vehicle weight reduction, I have just compared the Elan's glass to polycarbonate. Original glass weighed 18kg, add the rubber seals and it tops out at just over 20kg. Allowing for the front and rear fixings the polycarbonate replacements weigh 5kg, so around 15kg saving.
I’m interested!!!!!
I’m not sure if it’s allowed for App K, haven’t checked. I might do if the car comes in overweight.
Now that Restopower’s Elan speedster is on hold you are the only kid on the block.
Keep up the interesting work.
Graeme
S4 SE
S2 GTS
Peterson JPS Exige
S4 SE
S2 GTS
Peterson JPS Exige
661 - Fourth Gear
Made the rear screen today. Turned out pretty well, easy this thermoforming malarkey
- stevebroad
661 wrote:stevebroad wrote:For anyone remotely interested in vehicle weight reduction, I have just compared the Elan's glass to polycarbonate. Original glass weighed 18kg, add the rubber seals and it tops out at just over 20kg. Allowing for the front and rear fixings the polycarbonate replacements weigh 5kg, so around 15kg saving.
I’m interested!!!!!
What do you mean by App K ?
- stevebroad
Graeme,
App K encourages the use of Lexan. Just double check on the thickness that the FIA wish to see.
Andrew
Andrew
- Frogelan
Frogelan wrote:Graeme,
Andrew
But what is App K?
- stevebroad
I believe he is referring to appendix k of fia regulations.
- mbell
