Fuel injection: Pre instal advice appreciated .
Hello all,
The engine and gearbox of my Plus two is going to be removed in a months time. I would like to carry out some fuel injection prep work without disturbing the current setup. At this point I just plan to install the high-pressure fuel line within the chassis and leave for later, when I’m able to continue with the project.
I am considering using , “Classic injection “8 mm fuel line see https://www.classicfuelinjection.co.uk/fuelhose-8mmx10m for the Fuel supply line.
My questions are:
- Would it be okay to use the current fuel supply line as a return line to the tank when I get to the next stage?
- I hope everything else can be addressed with the engine and gearbox in situ at a later date, but Is there anything else I should consider doing whilst the engine and gearbox are out?
As I mentioned above, once the engine and gearbox are back in, I intend to be using the car, as normal while I plan for the next stage.
I would be very grateful for any comments on the questions above thanks in advance
Peter.
My questions are:
Peter.
1968 +2 BRM
- Peter +2
My advice (that I wish I followed on my EFI five years ago..) forget the return line and opt for a single line feed. And an in-tank pump and swirl pot ( that I did implement!) Much neater and cleaner. Do these now and the rest is easy bolt on.
Hal Adams
Evora SR
Elan +2
Evora SR
Elan +2
HCA - Coveted Fifth Gear
Not gospel, but also not the standard street meat found around the globe from dogs and cats in 3rd world places.
https://www.msextra.com/forums/viewtopic.php?t=65757
Hal, why do you figure a return line is not important. Every car has one since the first fuel injection?
Love your Mother
Earth
Love your Mother
Earth
Many thanks all for the quick replies, I had read Peter's post advocating return-less installs see:
viewtopic.php?f=31&t=39853
... and definitely open minded to either approach.
Reverting back to my questions, if deciding on a "Return" system, is there any technical reason as to why I should not use the current fuel pipe for the return?
I would love to here an update from Peter and I will certainly google Returnless EFI. and research further
Look forward to views.
Peter
Peter
1968 +2 BRM
- Peter +2
Hi Peter,
I'm going through this at the moment.
Last time I looked, Jenvey have some advice on their website on minimum pipe IDs for both 'returned" and returnless systems, for both the supply and return lines.
I don't know off the top of my head the size of the low pressure carb supply line but it could be a bit on the small side. I think (and I don't have my notes in front of me) that maybe -06 line is Jenveys recommendation? But if smaller it may be fine. (Edit: lots of conflicting info on the ID, some references to 8.7ish mm and others to 3/8", tbc.)
Personally I am opting to use nylon lines (as used in most OEM fuel injection systems.) They can be fitted to barb style connectors (plenty of YouTube videos showing how to) as they are compact and durable. The downside is the bend radii is bigger than rubber hose. I will also use a returned system, but each to their own on that.
As HCA mentioned, integrating the pump and other gubbins in the tank gives a cleaner install with fewer connections to leak, and likely quieter too. Also cools the pump. I posted a pic of the adapter I made for using an Elise pump in this thread viewtopic.php?f=39&t=49709&start=135 on page 9, which has a built in reservoir and swirl pot.
Will
Will
- ill_will
I am just doing the EFI for my Zetec conversion. I am using 3/8 Kunifer (I think thats the size) for the fuel line and return and a swirl pot with the fuel pump in that. (see link below). It sits in the boot floor just under the tank and is gravity fed.
https://www.ebay.co.uk/itm/204356015333 ... AZA&edge=0
All the best
Berni
All the best
Berni
berni29 - Fourth Gear
I hope kunifer is not an issue as I've been using it for seven years now. But then again some alloys are also not good with E10 fuel when it gets water in it.
Do not use the rubber-ish pipe through the cockpit, most of it is permeable so will stink the car out.
The return or no-return. There are issues either way. With a return it is said the the fuel can get too warm, without a return IF you get any vapour in the feed line it takes some time to come out. I have only had one problem and that was in Italy after leaving the car in the sun (40c) for a couple of hours it developed vapour in the fuel feed but the engine still started and because I have a return it fed through very quickly, 30 secs.
I run a LP and HP out of tank pumps with a swirl pot.
The system was installed over ten years ago now and things have moved on. IF I did it again I might well think about an in tank pump, but I would need to have a new tank made for a good installation.
Edit:- most of the pipe work Is PTFE braided with -6 AN fittings there is a small amount of kunifer.
YMMV.
John.
YMMV.
John.
- elanman999
I use Goodridge/Krontek flow and returns. It is light weight malleable ally that can be gently bent into position. The connections aren't cheap but careful planning meant that I needed 4 connections (flow and return) and the rest are traditional Goodridge fittings.
I use 10mm bore flow and return because on a two pipe system, the return is still pressurised (albeit controlled by the pressure regulator ahead of the fuel rail)
Because they are solid fuel lines, they can be run through the cabin if desired but if you do this, I strongly recommend that there are no joints at all in the cabin area.
Personally I wouldn't reuse the existing line - but I've always been a little extravagant
Hope this helps.
Gavin
Hope this helps.
Gavin
gav - Fourth Gear
