Buick/Olds/Rover 3.5 V8
Greetings to all...
This is "new guy" Bill Geary from Clarks Summit, Pa. USA.
I'm quite excited to join this forum. I recently bought a very special car. It's one of those beautiful cars that have been on my Wish List for more than 50 years!
It's a 1971 Lotus Elan +2 S. Build date 12/70. Body 00091-N.
Before anyone gets too excited, the seller only had the body shell for sale. It appears to be completely original, down to the early 70s strange Pumpkin Orange paint. It doesn't even have a Chassis under it!!
No front or rear glass either. Both doors do have glass tho.
No interior, except for a British dash which is very weathered. I hope to save most of the Smiths gauges?
Since I'm basically starting from scratch, I've pretty much decided to build my "Dream Car". This will be powered by either an early 60s BOP all-alum 3.5 V8, or the more modern Rover variant from the 80s-90s?
I hope to use the excellent 5-speed manual trans from the TR7 or TR8?
My first question is, may I use the Spyder chassis for this project? If so, I wonder if they will agree to modifying their current frame for the +2 to accept the V8??
I realize I will be de-valuing this little beauty but I have no intention of ever selling it! It's something I've wanted to do ever since I owned a 1970 Opel GT back in '72-'74!!
So there you have it. This is my first foray into the world of Lotus ownership. I look forward to hearing from anyone who's had experience doing such a big project?
Best regards to all,
96 Gears
Bill Geary
96 Gears
Bill Geary
- 96 Gears
Find a Lotus engine Bill and buy a proper Lotus chassis (no offence to Spyder and it's quality products btw, this would be purely my preference)...fitting a big heavy lump up front is a serious mistake, you will ruin the car and lose any investment you have in it. Don't imagine that a 1600 cc engine in this car is a major manufacturers base model...this is a sweet, sweet car, you will not improve it by shoehorning a heavier,albeit more powerful engine into it, ... Chapman and his team knew what they were doing, had it required a large engine to get the best all round performance they would have done it...Lotus are all about balance and handling, weight distribution is critical, if you lose that they would be no better than an MG C or a Sunbeam Tiger...OK in a straight line, can't go round a corner...like any front heavy car. Watch Jay Leno's video on his Elan...handling is the key....just follow Chapman's Lotus ( World Champion Car Constructor's) ethos. My worry is that you will accidentally turn an extremely good car into a dog.
- Sadbrewer
A good modern 4 or even 3 cylinder engine should slot in without a lot of hacking around of the chassis. Will make mince meat of an old 3.5L Rover V8. Key is not do do anything that isn't easily reversible should you wish to use a proper Lotus engine. I'm currently driving around in a modern car with a 3 cylinder 200HP engine - boy things have come a long way. Cubic inches are only for dinosaurs !!
1970 Ford Escort Twin Cam
1980 Ford Escort 2.0 Ghia
2022 Ford Fiesta ST.
- 2cams70
To install even a 'lightweight' v-8 in that car would require a very custom and much more substantial chassis, beefier suspension, etc, all massively increasing weight and absolutely destroying the beautifully balanced dynamics of the car. You'd end up with a pretty but otherwise highly compromised 'kit car'. So much for 'simplify and add lightness'.
But it's your car. Carry on as you wish.
Elan S1 1963-Bourne bodied
Elan S3 1967 FHC pre airflow
Formerly:
Elan S1 1964
Elan S3 1966 FHC pre airflow
Elan S3 1967 FHC airflow
Elan S4 1969 FHC
Europa S2 1970
Esprit S2 1979
Formerly:
Elan S1 1964
Elan S4 1969 FHC
Europa S2 1970
Esprit S2 1979
- bitsobrits
Something to get you started.
viewtopic.php?f=39&t=27803&start=
Scott
45/9011
Hawkestone, On, Ca
45/9011
Hawkestone, On, Ca
- snowyelan
How wide is the Rover V8?
If you just want more power, it would be simpler to go the Zetec route. https://www.spydercars.co.uk/lotus-elan ... -products/
- Lotus 50
Welcome.
If you want something modern that will just run and be fun, then the Zetec 2.0 is the way to go. The issue with the V8 engines is that they will probably be too physically big. Quite apart from heavy as has been pointed out above.
If you have time on your hand and money is not an issue then anything is possible, but with the Zetec's at least the hard work had been done by others. Plus the engines themselves are in the spirit of the originals.
All the best
Berni
Welcome.
All the best
Berni
berni29 - Fourth Gear
Agree with Berni, zetec route tried and tested, Spyder chassis better bet,
If you want originality that's great but I think a lot of people who drove a zetec Vs twin cam would choose the zetec, I think the plus2 should have gotten the BDA/BDG engines,
- elan66
elan66 wrote:Agree with Berni, zetec route tried and tested, Spyder chassis better bet,
The plus 2 was on the market before the engines you specify AFAIK.
- Sadbrewer
Honda K20 would be a cracking engine easy 200bhp and 9000 rpm
Ian
Ian
- elansprint
Lotus 50 wrote:How wide is the Rover V8?
This could be a real problem. Bill, have you had a chance to looks at a complete Plus 2 in the flesh? The chassis doesn't have much room for more than an inline 4:
Which is not to say that a small V can't fit, but the amount of modification of both the chassis and the body that would be required to make it work might be more than you really want to take on. I'm not saying don't do it, just be aware of what you're up against here.
The weight arguments are pretty valid too. The Buick/Rover V8 out-weighs the Lotus Twin Cam by more than 100 lbs. so in addition to all the chassis/body modifications, you'll need to make some changes to the suspension too.
All this is not impossible but whether or not its worth the effort is the question you'll need to put a lot of thought into.
2012 BMW R1200GS
2012 BMW R1200GS
The Veg - Coveted Fifth Gear
96 Gears wrote:Can someone please post the "all inclusive weight" of the complete Lotus engine and trans?
I think this will be very useful information to many of us!
I searched this site to inform my reply and around 230 lbs for the engine was the best figure I saw, based on one chap actually weighing his. No idea about the transmission but it's north of 100 lbs and I can grunt it off the ground and carry it SHORT distances. The search function seems to be malfunctioning at the moment so I can't find any threads addressing this.
2012 BMW R1200GS
2012 BMW R1200GS
Honda into Elan will go!!
Dave Hughes
S2 26R
Elan DHC Sprint
S2 26R
Elan DHC Sprint
bigvalvehead - Third Gear
Twincam, fully dressed with generator, carbs, manifold is 265lbs. Transmission is 85 lbs.
