Timing case on a Kent block
My plans have suddenly changed so that I must now build my engine with a Kent block.
I am interested in comments from anyone that has done this as well, particularly, from old posts
, Sean Murray, twincam man and garyanderson in how your installations faired through the years in regard to oil leaks.
I have two options, fit a spacer/shim on top of my existing short block timing case (although I have heard horror stories on this one, but was told by someone that it is better to have a spacer milled specially to suit the actual size as the off the shelf ones can be hit or miss) or, I can try and sell the short timing case and fit the Burton timing case that is readily available. (again stories abound of poor quality and oil leaks on this as well)
I am leaning towards the Burton option, and need to be persuaded one way or the other!
Hal Adams
Evora S
Elan +2
Evora S
Elan +2
HCA - Coveted Fifth Gear
A friend of mine did similar. He machined a spacer specifically the right height for his cover to head gap and used RTV sealants rather than the cork seal. Seems ok at the moment, well last time I asked anyway.
I have a full height 711 block for mine, when I get round to it. I will probably use the tall Burton kit myself as I dont have easy access to a mill.
SimonH - Third Gear
Well it's nice that someone remembers my 711 conversion !
I eventually bored this block to 84mm, and a cylinder got porous so it was scrapped and replaced with a QED 681F block bored to 85mm.
I never had any significant oil leakage problems with the 711. I had fitted a Burton tall block timing case/water pump, and I had this machined level with the block, there was quite a lot of extra height to be removed.
I found the best way to get a good sump seal was to have the block upside down on the floor and thoroughly degrease the joint surfaces with thinners. Carefully trim the groove seals, then use Dirku adhesive sealing compound with new Cometec gaskets. I barely tighten the bolts when fitting, then minimum torque them next day.
Socket head bolts make any sump work a lot easier.
Just today finished fitting a new clutch, during which checking for some oil leakage I found the old rubber breather tube had gotten extremely brittle and was cracked. Degreased and new breather fitted with Dirku. Wouldn't like to have to do this job with the engine in place
Back out for my first hillclimb since lockdown next week-end !
68 Elan +2, 70 Elan +2s
Foxie - Coveted Fifth Gear
Thanks Simon - how long has your friend's spacer solution been in place?
Thanks Foxie - how long has your Burton case been in use now? Any oil leak?
Thanks Bill, I am happy with the 711 conversion and what to expect (having said that, the mating of crank, rods and pistons is being done by a competent engine builder) I am only interested in pros and cons of the two timing case options open to me.
Hal Adams
Evora S
Elan +2
Evora S
Elan +2
I used to have a Seven with a 711 TC in it, used it for years and it never leaked at the spacer......did blow a head gasket though
