Calling Spyder Zetec owners - Engine Isolators
Does anyone have a picture of the rubber mounts which I think are referred to by Spyder as isolators.
- gordy7
Do you mean the rubber engine mounts? If so, I don't have great pictures but I do have these pics I took at a show a few years ago:
- Attachments
- IMG_2428.jpg (114.34 KiB) Viewed 553 times
- IMG_2302.jpg (150.57 KiB) Viewed 553 times
- IMG_2292.jpg (149.85 KiB) Viewed 553 times
- IMG_2291.jpg (160.12 KiB) Viewed 553 times
- mikealdren
Top man thank you. I'm trying to establish if the rubber mounts are a simple change as the ones on my car look like they are past their prime!
- gordy7
I’m running one that also wraps around the engine mount.
I was worried about the heat so close to the rubber so I wrapped it which works fine.
One tweak I’ll make next time is making a plate with the bolts welded on because screwing individual nuts on with the manifold in place is an awful job.
Gavin
Gavin
gav - Third Gear
Changing them is a good idea as the one near the exhaust manifold snapped after 8 years. Andy found it during the cambelt change and replaced it then.
1971 +2S 180/5 Spyder Zetec
- spyzee
