MSD Ignition
elancoupe wrote:The MSD cap #8434 and rotor #8470 come up in searches from Summit, Jeg’s, Autozone and others.
Btw, the cap also fits an MSD VW dizzy.
Excellent! Thanks for the correct call up part numbers.
Stu, I believe Concept 1 is in your town, Cowtown!
https://www.google.ca/search?q=concept1 ... nt=safari#
They are 123 dizzy distributors, last I checked. They dont stock Twink just VW, Ied take a set or two, and some LCCBC members have interest.
The Concept 1 guys are great. They were able to easily match up replacement CV’s for my aftermarket drive shafts. That said, I am happy with my MSD dizzy for the foreseeable.
Cheers!
Stu
Stu
1969 Plus 2 Federal LHD
Hi Stu
If you cant get the advance you want with the Dizzy hitting the block just move the dizzy to advance by moving to the next a tooth on the gear to the jackshaft which will move the body back the equivalent enabling more advance at the maximum advance position the dizzy body will go to. I have to do the same thing with the Bosch dizzy I use as the external condenser that hits the block if I don,t pick the right tooth setting
Excellent Rohan. I figured there was an easy fix. That should put the desired advance midrange on the adjustment.
Stu
Stu
Stu
