Adjustable rear wishbone
PostPost by: Sking06 » Tue Sep 01, 2020 1:57 am
Has anyone install the Kelvedon adjustable rear wishbone on their Elan? If so, any comments?
Thanks in advance
Skip King
‘69 Elan S4 SE
‘61 Seven S2 America
Sking06
New-tral
PostPost by: miked » Tue Sep 01, 2020 8:19 am
Skip,
If you are talking about the ones with the turnbuckle in the rear leg of the A frame,
no, but have fitted that design on at least 6 cars. Works very well. Slight turn corrects toe out.
Don't believe all the business about tension and stress. If you put the saw through the rear leg they generally pull apart leaving a gap. So under tension.
The amount of adjustemt to effect correction is so slight. Part of a turn. Plus you only do it once. Also you get to keep rubber or poly bushes.
There is an old thread on here were I showed how to make up your own (with photos) using an off the shelf turnbuckle. On round section Lotus A frames.
Cheers Mike D
Elan S4 Zetec
Suzuki Hustler T250
Suzuki TC120R trailcat
Yamaha YR5
Suzuki Vstrom 650XT
Suzuki TS185K
miked
PostPost by: gino1 » Tue Sep 01, 2020 10:20 am
Skip,
Totally agree with Mike's comments.
I made my own and the result is very good as a slight adjustment will correct any misalignment and or give you the desired set up.
Gino
1964 Elan S2 Roadster
1965 Elan S2 Roadster
1965 Elan S3 Coupe
1968 Elan S4 Coupe
1969 Elan +2
1968 Lotus Seven S3
1982 Lotus Esprit S3
1961 Ford Anglia
2000 Lotus Elise Motorsport-56
gino1
PostPost by: greg40green » Tue Sep 01, 2020 10:42 am
PM sent .
Thanks , Greg.
Sking06 wrote:Has anyone install the Kelvedon adjustable rear wishbone on their Elan? If so, any comments?
Thanks in advance
Skip King
‘69 Elan S4 SE
greg40green
PostPost by: Sking06 » Tue Sep 01, 2020 4:58 pm
Thanks for the positive input. I like the idea of keeping the original bushings...
Skip King
‘69 Elan S4 SE
Sking06
New-tral
PostPost by: Bits » Tue Sep 01, 2020 7:26 pm
Like these?
IMG_1428.JPG and
:D
Bits
