Alfa GTV 5 Speed Conversion
PostPost by: 1969Elan » Fri May 11, 2018 3:23 pm
I had a spec some years ago from an owner in NZ who completed a 5 speed conversion of an Alfa GTV gearbox I nto an Elan Plus 2.
My copy has disappeared after lending it out, does anyone out there have a copy of the document ???
It was held by Club Lotus in their library but sadly this has now been cleared of some old documents such as this.
Regards Iain
1969Elan
New-tral
PostPost by: fatboyoz » Fri May 11, 2018 7:54 pm
Hi Iain,
Don't remember an Alfa gearbox conversion, but there is this one from an NZ member:
lotus-gearbox-f37/detailed-report-five-speed-isuzu-t19828.html
Colin.
1969Elan wrote:I had a spec some years ago from an owner in NZ who completed a 5 speed conversion of an Alfa GTV gearbox I nto an Elan Plus 2.
Regards Iain
'68 S4 DHC
fatboyoz
PostPost by: 1969Elan » Fri May 11, 2018 8:53 pm
Thank you Colin.
It's a very comprehensive article.
The problem I guess with this conversion would be sourcing a suitable gearbox.
1969Elan
New-tral
PostPost by: toggle45 » Sat May 12, 2018 2:43 am
I know of one Elan, a '66 Coupe, that received a conversion to an Alfa 5-speed. It was done in Los Angeles in the late '60s. The owner IIRC was R. Elsinger, a mechanical wiz. Don't know if this helps, except as an indicator that it is possible.
Weldon
the dreaded PO himself
toggle45
First Gear
First Gear
PostPost by: lotusS2guy » Sat May 12, 2018 6:28 am
i knew that car and its owner, Dick Elsinger, well. The Alfa transmission was a beautiful installation. You would not have known that it was not factory stock. Does anyone out there know the whereabouts of car and/or owner?
Herb
26/4618
lotusS2guy
PostPost by: types26/36 » Sat May 12, 2018 11:24 am
When I first got my S2 it had been fitted with an Alfa 5sp box although the car was in pieces at the time, I never refitted the Alfa box as after some research I decided it was not the way I wanted to go and reverted to the 2000E box.
Probably of no help to you as from memory it was a 60's giulia box but here are some pics anyway.
alfa-box.jpg and
e.jpg and
f.jpg and
h.jpg and
i.jpg and
image1.jpg and
image12.jpg and
image13.jpg and
image14.jpg and
image21.jpg and
types26/36
PostPost by: alan.barker » Sat May 12, 2018 5:06 pm
Looks like a nice job to me. Did you sell it or have you kept it.
Maybe it is a stronger gearbox than the Lotus Maxi 5 speed :roll:
PostPost by: gjz30075 » Sat May 12, 2018 7:41 pm
What are the ratios of said box? Usually first gear is pretty short to handle the weight of a sedan
Greg Z
45/0243K Sprint
45/7286 S3 SE DHC
PostPost by: 65sunbeam » Sat May 12, 2018 7:44 pm
It's a shame no one does the mods to the bell housings to fit up an Alfa 5 speed-they are very nice transmissions and maybe that way I could use the ones I have on my Spider parts cars on my Elan?!
Eric
65sunbeam
First Gear
First Gear
PostPost by: types26/36 » Sat May 12, 2018 10:50 pm
alan.barker wrote: Did you sell it or have you kept it.
No I never kept it, I sold it years ago as from memory the ratio?s did not seem suitable with the fist gear being something like 3.5:1.
types26/36
PostPost by: crannyr » Sat May 12, 2018 11:39 pm
I did an Alpha 5sp conversion at least 10 years ago in my plus 2. To keep design as simple as possible we designed a spacer that duplicated the back of the Alpha bell housing on one side and the back of the Lotus Ford bell housing on the other. Therefore there was no modification for the starter assembly or the slave cylinder (I did decide to incorporate a concentric slave for reliability which added some additional design and fab) the spacer also allowed for more appropriate location of the shiftier. The only other mods were to the nut on the speedo drive, a change in the clutch assembly to suite the Alpha first motion shaft, modification of the Alpha case to accept an original Lotus trans mount, and a custom drive shaft. Still running today with no mods or replacements. Let me know if you are interested more details.
Rick
img00075-20101103-1306.jpg and
img00073-20101103-1305.jpg and
1348944482810.jpg and
img00072-20101103-1022.jpg and
crannyr
PostPost by: vstibbard » Sun May 13, 2018 1:26 am
I rallied and raced a 105 Alfam standard final drive is 4.1 with 165 x 82 series x 14" wheels, the gear ratios are as follows:
Standard gear box, ( there is a shorter 5th by using 1300 ratio)
5th - 0.791
4th - 1.000
3rd - 1.355
2nd - 1.988
1st - 3.304
I used the following Collotti Close ratio gear set in my race/rally car:
5th - 0.680
4th - 1.000
3rd - 1.260
2nd - 1.700
1st - 2.540
Lovely box to use, porsche type synchro's strong, lightweight all alloy, longer gear selection movement than 2000e.
V
PostPost by: jono » Tue May 15, 2018 6:52 am
I've got an Alfa Spider Veloce with this box in it.
It's an intriguing thought to put on in the +2 - it is a nice box to use however it has a very long throw to the shifter and the synchros are it's achiles heel.
...still, it's an interesting idea!
PostPost by: The Veg » Tue May 15, 2018 2:33 pm
My dad had a '76 Spider Veloce and a '74 Berlina, same powertrain in each. I liked that gearbox, which was made by ZF IIRC. Seems like the synchros were less than perfect but then I was a teenage kid with little driving experience and Dad's cars had some miles on them, each having had previous owners. I wonder how nice one of these transmissions would be after a rebuild and how long it would last.
As an aside, not long ago there was a Seven-family (LoCost?) Car for sale in my area that had the Alfa transmission and engine too. I should have gone to look at it.
2012 BMW R1200GS
The Veg
PostPost by: jono » Tue May 15, 2018 3:06 pm
..mine's a 76 as well!
I didn't realise the tranny was a ZF but the final drive certainly is a ZF LSD.
p1080561-copy.jpg and
Next
