Alternative pedal boxes ( Tilton anyone?)
I'm looking to fit a fully adjustable pedal box to my 26GTS
Ankle injuries mean I have to get the pedal spacing just right for heel and toe changes.(including pedal heights)
I'll need a bias bar too.
I like the look of the Tilton products but wonder if anyone has tried sizing them up in an Elan and, indeed , any success with using one?
Graeme
S4 SE
S2 GTS
Caterham 420R
Sold - Peterson JPS Exige
S4 SE
S2 GTS
Caterham 420R
661 - Coveted Fifth Gear
Hi Graeme
I'm also looking into this for my LHD car, but (ideally) plan to fit an overhead tandem brake master cylinder with a rear proportioning valve, in order to get more space for the exhaust manifold, extra heat insulation and a safer location for the master cylinders.
I'm going to seek advice from my local HTP inspectors first as their opinions are seem to take priority over the App. K (which is silent on this).
I had a look at the Tilton information but found the drawings tricky to comprend without an Elan body at hand to measure.
My search for an overhead (above the feet) solution took me to 3 options :
- Elan +2 version
- MGB pedal box (4 synchro pedals seem best)
- Caterham solution
The +2 and MGB pedal boxes would need (for a tandem system) to have either remote or the Caterham AP tandem master cylinder to give adequate bonnet clearance.
Both the MGB and Caterham solutions are also available with a balance bar (for the MGB ask the BCV8 championship competitors as to who the supplier is).
Andrew
- Elan +2 version
- Caterham solution
Andrew
- Frogelan
Keep in mind that a system with two master cylinders in parallel will lead to substantially greater pedal force required to achieve the same level of braking. Without going to smaller bore master cylinders the pedal force will double.
Russ Newton
Elan +2S (1971)
Elite S2 (1962)
Elan +2S (1971)
Elite S2 (1962)
I would agree, excep: The S Series Elans use a single (without servo) .70" master for Type 14 front and original rear calipers. My Plus2 arrived with no servos and its standard large bore master for a Type 16 front and standard to all real calipers. Pedal pressure was a two 2 foot operation. Switched to a dual 11/16", very close the single .70", from a Datsun/Sunny, and the pedal pressure is quite reasonable. However, with an adjustable bias between the masters, it may be preferable to downsize to 5/8" masters to achieve what one thinks as reasonable foot/leg pressure. YMMV. I did notice a Mk1 Cortina, without servo, using the same 11/16" master while at the Queens English car show last Sunday. Did not get the opportunity to talk to him at the time to see how he liked the change. Should also state the fronts lock before the rears with the new master.
Rob Walker
26-4889
50-0315N
1964 Sabra GT
1954 Nash Healey LeMans Coupe
26-4889
50-0315N
1964 Sabra GT
- prezoom
Thank you for these observations on pedal pressure (I'm the one who is planning to use a tandem system).
I will see if I can find a 0.7" tandem and combine this with a AP twin bore proportioning valve. I have no plans to cart a servo around !
- Frogelan
There is,of course, the tried and tested TTR version. I cant recall what size master cylinders Eddie said they use.
On a RHD car we obviously dont need to give the same consideration to the exhaust system, but at least your remote reservoirs can be plced closer.
Graeme
S4 SE
S2 GTS
Caterham 420R
S4 SE
S2 GTS
Caterham 420R
Graeme. I spent some time looking at options for Brake-Bias last year, before finally deciding to go with one from Paul at Kelvadon.
Couple of things not mentioned previously, that are worth considering.
1. It?s a tight fit getting a Bias Box in. You have to move the whole assembly further outboard, away from the steering column, or the connecting block that connects the upper and lower sections, will touch the pedal-box assy, when the steering is turned.
2. Moving the whole assy further outboard means the space to fit 3 master cylinders is now tight, if fitting them in the engine bay. Most seem to get round this by using shorter AP Master cylinder?s Its still too tight to get the outer most master in though, the clutch in my case, so we had to make a cut-out in the wheel-well.
Couple of pictures I took when looking at what others had used and done, before I took the plunge myself. Might be useful.
- Attachments
John "Freddie" Nelson, Berks UK
26/3212 - Rebuilding
S4-Sprint DHC - Now at a new home.....
- Fredtech
The bottom photo spacers scare me a bit, particularly considering discussions about the overall strength of the body laminations in this area. The spacers add about an inch to the lever arm of the pedal on the fiberglass, not an insignificant amount. I'm hoping that the surrounding materials are capable of comfortably handling that load, as the alternative during hard braking isn't pretty. Worse still with the higher pedal effort of a twin master system.
- denicholls2
Hi No problem Graeme. Denic is correct with regard to strength in the mountings. I thought that as well, so have used strengthening where the pedal-box fits the Upper and Forward section of the body. We also ground down the upper & lower steering rack connecting block to help with the clearance.
- Fredtech
I am aware that Raceworks use a different steering column, which I believe uses 2 U/J's so that they can place the steering wheel exactly where they want it, or perhaps it's also for the avoidance of the collapsible block fouling.
It looks like Pat's car has the reservoirs stuck out of the way in the drivers upper footwell.
Personally I think I'll put them in the engine bay above the ID plate.
Graeme
S4 SE
S2 GTS
Caterham 420R
S4 SE
S2 GTS
Caterham 420R
