Is there a new headlight activation systems out there?
What is the latest available to raise and lower the headlights?? Search turned up some alternative methods and ideas but was wondering if there was something recent. Maybe something in a "kit" form??
Mike in Sacramento
36-5706
Mike in Sacramento
36-5706
- bluesbrother30
I followed the ones in the Mods thread using a Mazda Miata unit, cheap as well. Depending on model, my mod was to a Plus2, it was quite simple.
Rob Walker
26-4889
50-0315N
1964 Sabra GT
1954 Nash Healey LeMans Coupe
26-4889
50-0315N
1964 Sabra GT
- prezoom
I noticed the other day that Paul Matty sells a kit:
https://paulmattysportscars.co.uk/product/electronic-headlamp-lift-conversion-kit/
draenog - Third Gear
draenog wrote:I noticed the other day that Paul Matty sells a kit:
That's the kit as made by Spyder based upon my design http://www.spydercars.co.uk/electricy-h ... an-elan-2/
These guys owe me some commission
Kindest regards
Alan Thomas
Alan Thomas
Mike,
I did my own system, using actuators from a Mazda Miata (MX5 over here in the UK). I found the work difficult, but educational, and I am pleased with the result. I suppose what you do depends on how you value your time and if you enjoy this sort of work.
Richard Hawkins
Richard Hawkins
- RichardHawkins
One thing I did with the Miata unit, was rotate the motor shaft with the red knob, so it pointed up towards the engine compartment. A piece of aluminum tube extended the shaft/knob up into the engine compartment, so the knob could be accessed and the headlights could be raised manually if there was an electrical problem with motor. The aluminum tube was broached with a cut off section of a 5.5mm hex wrench, which allowed the tube to slip over the exposed hex of the motor shaft. The far end of the tube was also broached and then the sacrificial piece of the hex wrench was glued into the shaft so the knob could be slipped over an extended section of the wrench. If there is a failure, all I have to do is raise the hood/bonnet and the knob falls right to hand.
Rob Walker
26-4889
50-0315N
1964 Sabra GT
26-4889
50-0315N
1964 Sabra GT
- prezoom
All, thank you for the information. With my work schedule and other car projects the Matty kit, although a bit pricy, is looking pretty good right now.
Mike in Sacramento
Mike in Sacramento
- bluesbrother30
Yes, thank you to all........great info. After a couple of PM's and phone calls, I have decided to go with a Miata motor on each headlamp. Simple and no hardware trying to join the two. Purchased a couple of motors from a member on prodracing.com.
Mike in California
Mike in California
- bluesbrother30
