NOW IF YOU WANT A CHALLANGE!
PostPost by: types26/36 » Thu Dec 12, 2013 6:21 pm
Now here is an engine to see off those Ztecs, Duratecs and BD engines!
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 9746467907
types26/36
PostPost by: john.p.clegg » Thu Dec 12, 2013 7:22 pm
And how many MPGs (or GPM.s) would one get out of that?
John :wink:
PostPost by: pharriso » Thu Dec 12, 2013 10:12 pm
Just imagine the acceleration!
Phil Harrison
1972 Elan Sprint 0260K
PostPost by: john.p.clegg » Thu Dec 12, 2013 11:36 pm
Performance
Maximum thrust: wet: 169.2 kN (38,050 lbf) dry: 139.4 kN (31,350 lbf)
Overall pressure ratio: 15.5:1
Specific fuel consumption: 33,8 g/(kN?s) or 1.195 lb/(h?lbf) (cruise) / 1.39 (SL) lb/(h?lbf)
Thrust-to-weight ratio: 5.4:1
John :wink:
PostPost by: rgh0 » Fri Dec 13, 2013 5:29 am
By my calculations the Elan fuel tank could supply it for around 15 seconds at cruise. So apart from a little extra heat shielding to the body, which should be easy as you have to do a little fibreglass work to fit the slightly larger the tail pipe, and a slightly bigger fuel pump, you would also need a bit larger fuel tank and it all should fit fine.
You would probably also need to convert the electronics in the tacho as the old current sensing unit would probably swing to much and under read a little. I would not bother with changing the speedo gearbox drive as you will not need the gearbox and the kind man in the car with the flashing lights will always tell you how fast you were going if here is any question about your speed.
PostPost by: gherlt » Fri Dec 13, 2013 6:44 am
15 seconds, you are kidding ...
WIKI:
Fuel consumption: 46.85 lb/mi (13.2 kg/km) operating for maximum range
Cruise speed: Mach 2.02 (?1,340 mph, 2,158 km/h) at cruise altitude
1 liter = about 0,75 kg
I am not sure how many liters are in the car, but optimistic 40 l = 30 kg
=> 30kg /13,2 kg/km = 2,27 km with 30kg
At 2158 km/h ~= 600 m/s => 2,27km / 600m
=> 4 seconds !!!
1964 S1 (all bits at home now)
1967 S3 DHC
1969 S4 FHC
gherlt
PostPost by: rgh0 » Fri Dec 13, 2013 6:53 am
I think 15 seconds for 1 engine - 4 seconds for all for engines on a concord?
PostPost by: rgh0 » Fri Dec 13, 2013 6:55 am
If you fitted all 4 Concord engines to an Elan then you would need the next size up fuel pump also and probably increase the size of the wiring to it in the loom
PostPost by: PeterK » Fri Dec 13, 2013 7:21 am
Maybe overkill, but just for peace of mind, I would also recommend a slightly harder brake pad as well.
Peter
PeterK
PostPost by: billwill » Fri Dec 13, 2013 9:41 am
You will also need to deal with the noise complaints from your local NIMBYs.
A year or so ago I stood about 150 yards away from a Victor that was testing its engines and couldn't hear myself think.
PostPost by: msd1107 » Fri Dec 13, 2013 5:21 pm
The Concorde, being a commercial aircraft, had noise levels, that while high, were acceptable.
The SR-71 was a different animal. For static tests, the surrounding area was cordoned off and you needed special passes even for that. The ground close to the aircraft would vibrate during the runup. The exhaust had pinpoints of compressed gasses that looked like diamonds. Preceding the Concorde (and roughly contemporaneous with the Elan) this was a sustained Mach 3+ aircraft at over 80,000 feet altitude, a performance level never even approached in the succeeding 50 years. The decommissioned aircraft are on display at various locations, but I do not think any of the engines made it outside.
David
1968 36/7988
msd1107
PostPost by: john.p.clegg » Fri Dec 13, 2013 10:30 pm
PostPost by: msd1107 » Fri Dec 13, 2013 10:36 pm
A different Blackbird, for sure!
msd1107
PostPost by: AHM » Fri Dec 13, 2013 11:27 pm
msd1107 wrote:The Concorde, being a commercial aircraft, had noise levels, that while high, were acceptable.
No, no, no, no,no,! :wink:
Concorde having 4 Olympus 593's, with full reheat on each at take-off, got fined by the US authorities for breaking noise regulations every time she took-off.
The Olympus 593 with full reheat produces 34,000 lbf the J58 only 32,000lbf. Concorde has 4 engines the SR-71 has only 2. So Concorde was roughly twice as noisy! This is a 1960's pure gasturbine with reheat - it aint quiet!
See also :
Bristol Olympus - First twin spool gas turbine - 1950
Avro Vulcan 1952 4 x Olympus 201 without reheat - A strategic bomber that could barrel roll in 1953.
TSR2 1964 Mach 2 2x Olympus with reheat
Concorde 1969, 4 x Olympus 593, Mach 2.2, range 3500NM, height 60,000ft ... While carrying 120 passengers!
Oh and if you want noise - English Electric lightning - Interceptor - 1958 , Mach 2, 2 x RR Avon with reheat climb rate 20,000 ft/min
Also Handley Page Victor - 1952 4x RR Conway - a strategic bomber that could loop, roll, and broke the sound barrier... But living in Radlett I am bias
AHM
PostPost by: AHM » Fri Dec 13, 2013 11:38 pm
msd1107 wrote:A different Blackbird, for sure!
From the performance at the Olympics - more a Warbler! or a Tit!
AHM
Next
