mechanical tacho drive
Here's what the original boss looks like.
Elfin Monocoque (Twin Cam)
[email protected]
[email protected]
SJ Lambert - Fourth Gear
[email protected]
[email protected]
I'm thinking Loctite 518 to seal the boss onto the cover and the gearbox onto the boss?
[email protected]
[email protected]
Put a sleeve over the driving shaft - just in case........
[email protected]
[email protected]
[email protected]
[email protected]
In case of what?
Could restrict 'slip n slide'.
Never heard of a drive failing there....
What's with the big lump of alli?
Drives that I have seen all bolt straight to the cover.
Roy
'65 S2
'65 S2
elj221c - Fourth Gear
The magnesium boss gets the driven shaft of the gearbox back far enough away from the jackshaft so as to mesh properly with the driving shaft and the gearbox itself also clears the water outlet on the front cover and allows the cable to be routed forward to the the dial - just slavishly copying the original set up!
[email protected]
[email protected]
