Brilliant Mod
While this is technically a modification, perhaps it really should be in the Elan section as it a.) is fully reversible, b.) invisible at a car show when the ignition is off and c.) really useful. Are you ready...wait for it...
Change the dual filament tail/brake light bulbs out for red LED bulbs. You will not believe how much brighter and redder they are than the old 1157 bulbs, and they increase your safety when folks can actually see your brake lights come on. Cost: $15.00 for two bulbs. I also bought yellow ones for the turn signals but they require a special flasher unit and I decided that the turn signals were bright enough as is so left them alone.
- Ross Robbins
Thanks Ross. I was nearly hit from behind a few months ago, so brighter brake lights are welcome. Can you tell us where you go the new lights?
Bob
Bob
- lotocone
Ross, I purchased 2 kinds of LED bulbs for a 65 midget a while ago and ended up going back to the 1157 because it was brighter. Of course the Midget had good reflector's in the tail light assembly unlike what my S1 will have but think that everyone should be aware that all LED's are not equal. Please let us know which ones you fitted if you can.
Kurt
26/3754
Kurt
26/3754
- nomad
I've been there as well,but gone back to filament as the LEDs are directional and couldn't get proper brightness for the size...
Sorry to be slow in responding. I just forgot to check back on this post
The LED bulbs I got were from Jam Strait via our local Auto Zone parts supply house. their website is here: http://www.jamstrait.com/1157s.htm and there must be an equivalent in Britain and Europe.
I talked to a friend of mine who had a BMW 2002 and he gave me the insight to get the red LED not the clear one so I did and am delighted. They are much much brighter than the incandescent bulbs so I am not sure what your LED was John that it wasn't as bright as an incandescent. I do know that these come in several levels of brightness and I got the super bright ones.
I suggest you look at them again to see if there are better alternatives now available. I am quite happy
with the change especially as it is so easy to do and fully reversible if for some reason it were warranted, though I cannot imagine why.
- Ross Robbins
I fitted a red LED bulb to the rear light of one of my Honda motorcycles almost 10yrs ago (it was a quick fix for a vibration problem continually breaking the filament of the normal bulb) and the first thing I noticed was that it was almost too red. The light unit seemed to glow - I know it's supposed to do that
but it just looked odd, as though the intensity of red had been turned right up - almost to the point where it was hard to focus your eyes on it. Red inside a red cover just seemed to be too much err... red and while I've kept it in that bike the effect has put me off using red bulbs in the Elan.
I agree about the directionality. Most bike rear lights illuminate the number plate using light spill through a small clear section of the cover and this bulb sends it all directly backwards so nothing spills out the bottom. There are better designs on the market now though.
Stuart Holding
Thame UK / Alpe D'Huez France
69 S4 FHC
Honda GoldWing 1800
Honda CBX1000
Kawasaki H1 500
Yamaha XS2
69 S4 FHC
Honda GoldWing 1800
Honda CBX1000
Kawasaki H1 500
Yamaha XS2
- 69S4
I've been looking into fitting a full set of LED's to my Elan for a few years. You do need to be very aware of the type of bulb you use as some will not light up the reflectors and will look worse. I believe ultraleds website provides quite a selection.
On the intensity - - a red Led is all Red light so it all passes through the red lens. An ordinary bulb is white light and the red lens only lets the red part of the spectrum through. Hence the Leds are brighter.
Do not discount the other positives with Leds - they will last the lifetime of your car so in effect a once only fit (they last thousands of hours and are resistant to damage from vibration and knocks). They operate significantly faster buying many metres of stopping distance in an emergancy situation at say 30/40 mph and may actually save you from a rear end impact. They use significantly less power and as such when you have electrical problems are much more likely to work than an ordinary bulb
Silence is Guildern; Duct Tape is Silver
elanfan1 - Coveted Fifth Gear
Elanfan1,
Good info on this LED direction, I plan to get a set for my 68 SS S3 and 69 S4 DHC, perhaps a silly question you can help me with, I am not to BRIGHT on LED's, my 68 SE is positive ground, does it matter to the LED?
Alasdair.
1953 David Brown Cropmaster
1954 S1 Land Rover
1962 Elite S2
1966 Lotus Cortina MK1
1968 Elan S3 SS Coupe
1968 Austin J40
1969 Elan S4 SE DHC
1972 Elan Sprint
1954 S1 Land Rover
1962 Elite S2
1968 Austin J40
1969 Elan S4 SE DHC
1972 Elan Sprint
- Alasdair
Suggest you make an enquiry through Ultraleds website Wth a normal 12v bulb it makes no difference which way power goes through it (not that you could fit it the wrong way anyway).
I believe some led lamps are fitted with some sort of resistor that might have an effect on the polarity - it is best to check. Post the answer up here for everyone else.
All LED's are polarity conscious & need to be connected the correct way round to work. Re the directional bit, if you get them with LED's around the edge of the bulb as well they should work just fine. I've bought them for my build & they look great, really bright
- Junks
