fuel pressure measurement with EFI
Hi Folks
Fitting an EFI to the twink. Just a simple question ( I hope) can I read the fuel pressure at the blanked off port on the fuel pressure regulator?? I assume the pressure should be read on the output side of the fuel rail
the attached note explains the question fully
thanks in advance 4 help
Bob
Bob
- Attachments
- Fuel Pressure Regulator Connections2.doc
- (431 KiB) Downloaded 589 times
- bob_rich
Bob,
From your picture both ports with arrows will be a straight line connection - so the blanked port can be used for a pressure gauge. FWIW, this confirms Gerry's reply.
Brian Clarke
(1972 Sprint 5 EFI)
(1972 Sprint 5 EFI)
bcmc33 - Coveted Fifth Gear
Users browsing this forum: alfadave and 11 guests
