Buick/Olds/Rover 3.5 V8
If the v8 is 315 lb then that's another 50 lb up front? Could work. I'd be much more concerned that it may have to shift forward to fit a wider part of the forked frame. An alternative project would be to put the v8 in a Europa, where there is plenty of room, and precedence. I have a v8 that I'll cast an eye on for fit. Never thought about that before. John
- baileyman
Thanks very much John!
Over the years I've dreamed of putting the 3.5 V8 into a Europa, but I've never found the right candidate....
In the meantime, I found this beautiful all original +2 body. Unfortunately it's nothing but the bare body shell!
I've already heard back from Spyder in England. They will NOT modify their chassis in order for me to fit the 3.5 V8. So I'm on my own if I want to attempt to notch the frame rails!
At this point, I'm still just doing the research to determine if this is a viable project?
Best regards,
Bill Geary
Best regards,
Bill Geary
- 96 Gears
There is a company in England that puts Jaguar V6s into MX-5/Miatas. It's said to not spoil the handling. Given that the Mazda's heritage is the Elan this may be the way to go. Apparently the engine weighs about 230 lbs.
Have a look at Rocketeer
https://www.rocketeercars.com
1969 Elan S4 FHC, purchased in 1978, now with a big valve engine.
- JohnMorin
I'm all for building your dream/ forever car and you started similarly, but different from me. I picked up a frame first and plan to 'drape it' later once the frame is a roller with a drivetrain installed...
That said, I also want to discourage you from the V8 path, or any V-motor due to simply not having the space. The pic of the motor with no body should give you an idea as to how tight the space is.
Whatever path you choose, I will be here watching. I am also a fan of the Aluminum V8, but dont think the Elan (+2 or otherwise) is the right destination for it.
-Simon
- 2mAn
96 Gears wrote:Thanks for your reply...
I'm still awaiting delivery of my complete rolling +2 chassis. It's looking less and less likely that the 3.5 V8 will fit, though.
What are your thoughts on using the 2 liter inline 6 from a Triumph GT6?...
Bill
Waaaayyy too long and heavy. If you must swap in another engine, the 2L Zetec is the preferred choice. 150 hp and lots of torque stock. Will also make as much power as your wallet can stand.
Bill
Waste of time Bill.. adding weight with an engine that, despite being a 6 cylinder, produces less power than a standard 1600 Twin Cam, never mind a big valve Sprint engine.
- Sadbrewer
