Smiths fg 2530/71 fuel gauge not working
PostPost by: Sandals man » Mon Feb 13, 2023 9:33 am
Hello everybody,This is Willem from Holland.I need advice.
I finished my restauration from the s3 and fuel gauge not working.I checked the tank sender unit and it had a broken wire inside.Bought a new one from SJ.Checked the ohm full and empty 6 and 80 ohm which is correct.Still no gauge moving.I put 12 volt on the gauge and measured on the side going to the sender 1, to 6 volt ?when moving the sender unit arm.There was no voltage stabilisator on my s3.I changed the polarity on my car to negative is ground.Am I correct that I did not change the polarity on my gauge wires?
I searched on this elan net but do not know what to do.
Thanks for helping
Willem from Holland
Sandals man
First Gear
First Gear
PostPost by: Craven » Mon Feb 13, 2023 12:40 pm
Gauge in an early S3 has a 3 wire connection. See this article should make things clear.
https://mgaguru.com/mgtech/electric/fg_10.htm
PostPost by: Sandals man » Mon Feb 13, 2023 3:35 pm
Craven thank you but my fuel gauge is fg 2530/71 which has on the left a double blade for the green + wire and another green wire connection that goes to the flasher unit and on the right side a blad for connecting a green/black to the sender unit.Any help welcome
Willem
Sandals man
First Gear
First Gear
PostPost by: Craven » Mon Feb 13, 2023 5:28 pm
I was going by your reading of the tank sender ohms, 6 to 80, if correct this is the sender for a 3 wire gauge. 2530/71 is a 3 wire gauge connected as shown in link.
50924900158_ee49f2de1a_c.jpg and
PostPost by: Barney » Mon Feb 13, 2023 8:22 pm
Came across this for FG style gauges, hope it helps.
Fuel Gauge test.pdf
(190.05 KiB) Downloaded 256 times
Elan S2 DHC (26-4399),
Barney
cron
