1965 Lotus Elan Drop Head
Posting this for a friend. For more info contact [email protected]" target="_blank" target="_blank" target="_blank" target="_blank" target="_blank" target="_blank or call Bruce at 908-507-5140.
1965 Lotus Elan S2 Drop Head
This car is not a #1 but a solid #2. It has about 1,200 miles since being restored about a year ago by Bob Herzog in Illinois. (His photo archive is on the web at: http://www.lotuscorps.org/pictures/inde ... ategory/15 )
It is an early S2 with triple tail lights and Weber carburetors.
It runs very well and over the 1,200 miles has been sorted and de-bugged from any issues.
Car is located in Cranford, New Jersey. (About 20 miles southeast of New York City).
Attached is an outline of what was done to the car. Most, but not all, of the receipts are with the car. There is also a photo archive.
Inspections are invited and recommended.
ENGINE - Original to car. Engine Rebuild (Apex Engineering, Bensenville, Illinois). New Rings. Bearings. Seals. Block bored. Crank polished. Upgraded rods. ARP bolts. HEAD - Upgrade to SE spec cams. New big valves. Guides, Springs, Seats. Cam followers. New oil pump. Water pump rebuilt. CABURETORS - Weber 40 DOCE cleaned and rebuilt. ELECTRICS - Gear reduction starter. Pertronix ignition. Lucas Sports coil. GEAR BOX - Syncros are good ? no grinding, easy shifts. New front main bearing. All seals and gaskets replaced. REAR END - New seals and gaskets. CV joints replace problematic ?donuts?. GAS TANK - Boiled out. Treated with Renu. EXHAUST - Stainless Steel original style. ELECTRICS - Rewired to Negative Ground. New Wiring harness. Alternator (original generator comes with car). New battery. Battery cut-off switch. GAUGES - All rebuilt and function appropriately. BRAKES/HYDRAULICS - Rebuilt calipers with SS pistons. Rebuilt master cylinder. Rebuilt clutch cylinder. SS braided hoses. SUSPENSION - Coil-overs, front and rear (AVO adjustable). All new bushings. Steering rack rebuilt. All parts media blasted and powder coated. New tie rod ends. Trunnions rebuilt. New tires. COOLING/HEATING - New four row radiator. Heater core boiled and tested. Electric cooling fan. CHASSIS - NOT original to car. Checked for alignment. Media basted and powder coated. Additional steel plate added for rigidity and jacking. BODY - Bare fiberglass respray in Monaco White. New closed cell foam pad between body and chassis. All gaps are as good as original. Steer bolt-on wheels media blasted and repainted. New window channels and brush strips. INTERIOR - Original dashboard refinished. Original steering wheel restored. New seat covers and padding, door panels and floor mats, including boot. Dyna Mat under layment. Competition lap belts. WEATHERT EQUIPMENT - New Robbins top and tonneau. Top frame and window frame refinished. CHROME - All chrome re-plated or replaced.
MISCELLANEOUS - Shop manual and Owner Manual. Original Jack. Car cover. No Cup Holders.
Priced at $52,000 US
- zog
