*** Removed from Sale *** 67 S3 SS DHC Project For Sale
I've decided to complete the project and so it is no longer for sale. Thanks to those who have inquired.
jf
I am selling my 67 Elan project. It is very close to completion but I must part with it.
36/7480, LP9254
Photos are at: http://s1095.beta.photobucket.com/user/ ... tus%20Elan" onclick="window.open(this.href);return false;
Current status: Most electrical work is complete. Low speed on the defrost motor is not working. The engine was run on a dyno and returned about 150HP at 6500rpm with about 123 ft. lbs. Dyno sheet is available.
I recently changed the oil pan and pump to a John McCoy pan and pump. These are installed but the remote oil filter needs to be plumbed.
The interior needs to be completed. A good-condition top is included as are two frames.
Updates:
frame gusseted and powder coated
New AVO 2.5" coil overs
New Poly bushings front and rear
New Quaife diff with original 3.77 ratio
New gaskets in transmission
New clutch, clutch master cylinder and slave cylinder
New brake master cylinder
New brake hard lines and Stainless flex lines
Brakes rebuilt with new pistons and seals
Engine:
JRE 10.5:1 pistons
Elgin reground cams to .430 lift @ .290 duration
Dave Bean 4-2-1 header
2.5" oval aluminized exhaust to SpinTech aluminized muffler (straight through which may require a resonator tip).
Dual Webers with Keith Franke Hypo tubes etc.
Gas tank cleaned and sealed. New hard lines installed with stainless flex pipes where needed.
Several sets of door panels and other spare parts.
Needs final tuning, EGT installation, O2 installation, suspension set up, interior (carpet) and side panels (not included) and windshield installed. Other items I was on the look out for: ash tray, jack, wiper arms, glove box handle.
$20,000.00
jf
36/7480, LP9254
Updates:
Engine:
JRE 10.5:1 pistons
$20,000.00
- jfornarola
Hi, Were are you located?
Please send a number where I can call you.
I am interested in this car.
thanks
Scott
San Francisco, CA
thanks
Scott
San Francisco, CA
Current: 1965 S1.5 26/4004, 1966 S3 FHC 36/5192, 1958 Fiat Abarth 750GT Zagato, 1967 Brabham BT21B, 1988 Arrows A10B-04, 1991 Brun C91-001.
Past: 1971 Elan S4/SE DHC, 1972 Europa Special, 1980 Esprit Turbo, 1988 March 881-05, 1990 Leyton House CG90105
CG901 - Second Gear
