Lotus Elan
Handbrake cable install.
PostPost by: StressCraxx » Thu Nov 21, 2024 5:59 pm
I'm faced with threading the handbrake cable through the aft section of the chassis. I have been unsuccessful pulling the cable end through the cable ferrules at the bulkhead ahead of the diff. The cable end hangs up on the forward side of the ferrule. It's the original cable and the diameter is smaller than the ferrule.
Your thoughts? Thank you.
StressCraxx
PostPost by: vstibbard » Fri Nov 22, 2024 12:39 pm
I’ve had that issue in past, I carefully filed the ferrule until it passed through.
V
PostPost by: StressCraxx » Fri Nov 22, 2024 5:55 pm
Thank you, V! I will give that a try.
Dan
StressCraxx
Users browsing this forum: pianoderby and 25 guests
