Engine vibration
PostPost by: hector9 » Fri Jul 26, 2024 2:09 am
Hello, I am having a problem with a small elan s4/sprint where engine vibrations are being transmitted into the car and causing a very uncomfortable feeling. Has anyone taken measures to prevent that?
Looking forward to everyone's advice. Thank.
hector9
New-tral
PostPost by: rgh0 » Fri Jul 26, 2024 4:52 am
Check that you engine mounts have not collapsed and that the carbs are not hitting the footwell.
PostPost by: promotor » Fri Jul 26, 2024 3:18 pm
hector9 wrote:Hello, I am having a problem with a small elan s4/sprint where engine vibrations are being transmitted into the car and causing a very uncomfortable feeling. Has anyone taken measures to prevent that?
It might be worth checking whether your flywheel and clutch bolts are tight.
promotor
PostPost by: MACCA.GLM » Fri Jul 26, 2024 7:31 pm
Hi Hector
Just put a reply on what did you do to your elan today
Regarding your vibration Rohan has said check the engine mounts. This is exactly the problem I had with the same symptoms as you have.The cause was a collapsed engine mounting on the passenger side NSide. take off the bonnet and look at the engine if its listing excessively to one side its probably the engine mount. My mounts have only done 2500 miles so the bonding of rubber to steel now is rubbish.
Hope this helps
G
MACCA.GLM
PostPost by: Sadbrewer » Sat Jul 27, 2024 12:41 am
Engine mounts most likely, probably the one under the ex manifold as it takes the most heat.
Sadbrewer
PostPost by: h20hamelan » Sat Jul 27, 2024 6:55 am
Alternator bracket bolts etc.
Love your Mother
Earth
cron
