Thermostat Housing
Hello,
I need to change the thermostat housing gasket on my Sprint.
I’ve checked the Lotus workshop manual and can’t find a recommended torque setting (ditto Haynes manual)
Drawn a blank with an internet search too.
Can anyone help me with that ?
- Cadence
It's a thermostat housing. It's not critical. Tighten until 'fully snug' with a short ratchet handle. Keeps you from over doing it. FWIW I use studs, not bolts to hold the housing in place. Avoids the wear on the cylinder head threads from bolts going in/out.
Elan S1 1963-Bourne bodied
Elan S3 1967 FHC pre airflow
Formerly:
Elan S1 1964
Elan S3 1966 FHC pre airflow
Elan S3 1967 FHC airflow
Elan S4 1969 FHC
Europa S2 1970
Esprit S2 1979
Formerly:
Elan S1 1964
Elan S4 1969 FHC
Europa S2 1970
Esprit S2 1979
- bitsobrits
Congratulations you are well on the way to not becoming yet another DPO by asking the right questions. Usually the correct figure for that bolt size is 12 - 15ft/lb but allow me some time and let me check the workshop manual. As original is best.
1970 Ford Escort Twin Cam
1980 Ford Escort 2.0 Ghia
2022 Ford Fiesta ST.
- 2cams70
bitsobrits wrote:It's a thermostat housing. It's not critical. Tighten until 'fully snug' with a short ratchet handle. Keeps you from over doing it. FWIW I use studs, not bolts to hold the housing in place. Avoids the wear on the cylinder head threads from bolts going in/out.
I imagone you use Studs on the Exhaust Manifold then lol
- alan.barker
'I need to change the thermostat housing gasket on my Sprint'
Why does it need to be changed, and out of interest, what degree stat are you using? Sorry, I didn't catch your name. If the surfaces of the head and housing are in good condition, ie not corroded, and flat, there is generally no problem in that area.
I did this job last week, to fit a 74 degree stat. I was using a 78 degree one, but this particular engine runs just a bit to warm for my liking in summer with one of those. Dry off the surfaces, fit the new stat with a smear of grease on both sides of a new gasket and just snug it up, with bolts and anti seize of course.
One thing I noticed years ago, that after a few heat cycles, the gasket compresses and the bolts need to be retightened. Same for the cam cover gasket, but that of course is cork.
Good luck with it.
Leslie
Good luck with it.
Leslie
- 512BB
I've just checked the workshop manual and can confirm that the correct torque spec.is 12 to 15 ft/lb. Per the manual the correct thermostat is one with an 85C to 89C opening point. A lot of people seem to think that it's a good idea to use a lower rated thermostat however in the absence of good scientific information that the original thermostat rating is wrong I'd suggest it's best to use what the smart guys who designed the engine in the first place recommend.
You're well on the way to becoming a professional rather than an amateur by asking about tightening torque specifications. Next step is to obtain some genuine factory workshop manuals.
- 2cams70
2cams70 wrote:A lot of people seem to think that it's a good idea to use a lower rated thermostat however in the absence of good scientific information that the original thermostat rating is wrong I'd suggest it's best to use what the smart guys who designed the engine in the first place recommend.
A lot of engine designers had to make compromises to meet government mandates. This is a fact.
- Uturn
I don't believe when the Twink was designed that there were very many if any government mandates. I am relying on my 80 year old memory though.
Keith Marshall
- saildrive2001
Uturn wrote:A lot of engine designers had to make compromises to meet government mandates. This is a fact.
Please show me the facts that this meant that they needed to use a higher thermostat rating than you guys think is right.
- 2cams70
https://www3.epa.gov/ttncatc1/dir1/fnoxdoc.pdf
TLDR
Hotter engines are more efficient. Efficient engines reduce NOx emissions.
Common sense - the twink cannot be an efficient engine and a powerful engine unless you institute modern spark controls and air/fuel metering. Not sure how much a colder thermostat will help reduce pinging vs just using higher octane fuel but every little bit helps if you're chasing numbers.
2cams70 - I'm in the same camp as you, put in what the manufacturer spec'd if it's a stock car or a customer's. However, I feel we all should be free to experiment, if it doesn't work out, we can swap back to baseline.
TLDR
- Uturn
Feel free to experiment but all the thermostat does is regulate the minimum temperature. It doesn’t regulate the maximum temperature. That’s why you should leave it as the manufacturer intended. The consequence of an engine running too cold is increased engine wear - not something that necessarily leaps out at you and hits you in the face. Replacing the thermostat with a lower rated one is usually down to psychological reasons and not reasons based on fact.
- 2cams70
2 cams wrote 'Per the manual the correct thermostat is one with an 85C to 89C opening point. A lot of people seem to think that it's a good idea to use a lower rated thermostat however in the absence of good scientific information that the original thermostat rating is wrong I'd suggest it's best to use what the smart guys who designed the engine in the first place recommend'
And also wrote 'The consequence of an engine running too cold is increased engine wear - not something that necessarily leaps out at you and hits you in the face. Replacing the thermostat with a lower rated one is usually down to psychological reasons and not reasons based on fact'
See picture taken from my Lotus workshop manual. I think some folk must be looking at their cookery book. Now I will give you some facts.
Every Twin Cam in every Elan runs differently and has its own likes and dislikes as far as starting, running, temperature, settings etc. There are not 2 in the world that run exactly the same.
I rebuilt an engine with 40k miles on it, that I had run for 30k of those miles with a 74 degree stat in. There was NO discernible wear on any component, inc the rings, so I just cleaned it and put it back together, and 80 miles later drove off to France in it. So much for increased wear.
There is not a single member of this Board who runs their road going Elan with an 89 degree stat in. In my experience, gained from over 40 years of running Twin Cam engines, they do not like to be run excessively hot, and start to get lumpy when they are. With a 74 degree stat fitted in my every day Elan, it runs at 80 degrees on the dial, and that is perfect. With the 78 degree stat fitted, it ran at 85 degrees, and did not leave enough margin for my liking.
Leslie
Leslie
- 512BB
What year was that workshop manual you are reading from Leslie published?
Mine is a 1970 Ford publication. They may have upped the temperature on later cars. The thermostat has no relationship whatsoever to whether the car overheats or not. 90C is not an engine overheating. It's an engine running efficiently. If your cooling system is blocked or inefficient and the temperature reaches 97+ it will happen with any thermostat you may put in the engine that is rated under that figure
- 2cams70
