Elan S3 1966 FHC
Hi Frampty,
Carefully cut or grind away the old clamp screw and then buy two of my clamp screws from Sue Miller. The design removes the risk of breaking the glass on assembly.
Sorry, but I had to get that in. It is too late at night to find a photo, but can do it tomorrow if you wish.
Eric in Burnley
1967 S3SE DHC
Eric in Burnley
1967 S3SE DHC
- ericbushby
Hi Geoff.
The old fashioned way of dealing with scary and difficult jobs is to go away from it for a bit or do it tomorrow.
It works well and you will have devised another way of doing it by then.
I do it a lot. Brew time is also known as thinking time.
Good luck
Eric.
Good luck
Eric.
- ericbushby
Hi Geoff,
Well done. I also have a rattling door and I am interested to learn what you did to cure it. Mine is no better with the window up or down or wedged to prevent it moving.
I have had lots of attempts to fix it but with no result yet. What I have not done is strip the door down, but I can see that coming soon. Any suggestions will be welcome.
Eric
Eric
- ericbushby
On my car, the rattle was the window motor vibrating, both sides. With the door card removed , I could tap on the lower frame and replicate the rattle.
There are several solutions , such as making a support brace, or adding a little closed cell foam around it.
I converted to the modern style motors, which are much lighter (and faster) , and also vibrate less.
- elancoupe
Users browsing this forum: vstibbard and 15 guests
