Elan won’t start
Hi All,
My elan has been sat for a months while the new garage was being built. Now it’s done I’ve tried to start her up but no luck.
Replaced the fuel, Webber carb jest seem clear fuel gets through, spark is there on all plugs from the electronic ignition.
Car did run with electronic ignition before it was stored while garage being built.
She refuses to fire up, I’m at a loss
Please help
Please help
- gazzamuffin
Fuel deteriorated. Drain and refuel with fresh petrol
first step.
first step.
+2s130 1971
+2s130 1971
Hawksfield - Fourth Gear
Hi John, yeah I thought that so drained and replaced with fresh fuel.
- gazzamuffin
If you’re in Gazza, there could be other issues. Hope your okay
Love your Mother
Earth
Love your Mother
Earth
rgh0 wrote:check you have fuel in the carbs. The float valves can gum up and stick closed
And do that by taking the cover off one of the carbs and checking that the float bounces up and down when you poke it, ( carefully.....), with a thin wire. If it doesn't, you're not getting fuel through.
Then pull a plug wire, hook it onto a spare plug that's resting on the cam cover, use the push up button on the bottom of the starter solenoid, and see if you're getting a spark.
Ralph.
- reb53
