Foam behind dashboard
PostPost by: NTG999 » Tue Jan 02, 2024 9:09 pm
When I removed my dashboard there were 2 rolls of foam jammed in (I can't remember quite where). The look quite old, is this Lotus original? If they are any guidance where they go?
PXL_20240102_204942341.jpg and
NTG999
PostPost by: richardcox_lotus » Tue Jan 02, 2024 11:47 pm
I can’t comment on that specifically, but having recently removed and replaced my temp gauge, it’s easy for the various cables to vibrate within the voids behind the dash, creating irritating rattles/noises
What you are seeing may simply be an attempt to improve NVH, if not by the factory, then maybe a dealer or owner
'72 Sprint
PostPost by: Craven » Wed Jan 03, 2024 12:47 pm
Typically found pushed in-between inner and outer front wings behind dash and sort of in line with bulkhead. Block air flow I guess.
PostPost by: RichardHawkins » Wed Jan 03, 2024 5:28 pm
As Richard Cox mentions, except in my case to take up the slack and vibration in the radio aerial.
Richard Hawkins
RichardHawkins
