Replacement keys
On my late S3, the key blank was for an MGB. You can have a competent locksmith make you new keys.
They are very common lock barrels, as used in many filing cabinets etc.
The number will be on the barrel, but it's almost impossible to get the barrel out intact if you don't have its key.
You could stymie any thieves by fitting non standard barrels such as those which use a cylindrical key. Ages ago when I had similar problems I fitted the doors with key barrels that needed keys with both edges shaped. I still have them fitted now.
Once these non-standard barrels prevented the police from opening my S3 Coupe & so I left fine-free after parking for an excess time in Soho.
billwill wrote:Once these non-standard barrels prevented the police from opening my S3 Coupe & so I left fine-free after parking for an excess time in Soho.
I'm intrigued.
Why did they need to open your car, what were they planning on doing if they had been able to, and what prevented them from issuing you an infringement notice regardless ?
If you've found a loophole I want to know about it !
Ralph.
- reb53
reb53 wrote:billwill wrote:Once these non-standard barrels prevented the police from opening my S3 Coupe & so I left fine-free after parking for an excess time in Soho.
I'm intrigued.
Ralph.
I don't really recall what the rules were back then in the 70's, I just seem to remember that they found it amusing and let me off. I think that the policeman who was expecting to drive my Elan to the pound was dis-appointed. The police used to like Elans back then, modern younger policemen usually don't even know what they are
They were trying to open it, with a huge bunch of keys, because it had been parked there too long. (I was browsing in "Dark they were and Golden Eyed"). Possibly it was before the Authorities switched to using take-up trucks that do not need to open the car. (though much later (1990's ?) I did manage to rescue my Elan in Mayfair after they had actually fitted the slings, and they let me off that time too.
I had a similar thing happen when i had an Austin Cooper S.
They couldn't open the doors because i had fitted Lander Locks in the Body.
- alan.barker
I’ve seen a good locksmith make a key from scratch, and it’s particularly easy if they start with the right slotting on the key, and I’m pretty sure that’s the same for all Elan’s, maybe start by buying just a key blank Gordon
- Gordon Sauer
If you remove all the Barrels and the keys are the same series e.g. TS OR FS. You can change the Wards around so the same Key fits all the Doors etc.
P.s. if you find a good Key that fits don't show us a photo of it. Keys can be cut using photos.
- alan.barker
Hi Paddy,
If you have the number, keys are readily available on ebay.
Eric in Burnley
Eric in Burnley
- ericbushby
Found this old topic. viewtopic.php?f=16&t=7460
Apparently Austin only ever used 14 different key numbers for their 1100 range (S3 handle/lock), which should make finding a matching key slightly easier.
1967 S3 FHC
1968 S4 FHC
1967 S3 FHC
1968 S4 FHC
- smo17003
Users browsing this forum: The Veg and 27 guests
