Center Console removal
Hi all,
I’m a newbie. Does the center console pull out without any tool? I pulled out vinyl cover padded console altogether. I see some kind of fiber glass tunnel. Is that what’s covering the 4 speed gearbox? I wasn’t sure if I can pull out the fiber glass tunnel…
Thanks in advance.
GElan
Thanks in advance.
GElan
- GElan
Hi Gelan
The fibreglass tunnel which you have uncovered is part of the bodyshell and not removable. Below that is the folded steel chassis. The gearbox comes out forwards with, or after the engine.
Eric in Burnley
1967 S3SE DHC
Eric in Burnley
1967 S3SE DHC
- ericbushby
GElan wrote:Got it. Thanks.
I was looking around the forum and the ABS center console replacement looks nice. How does it fare against heat and sound insulation? I suppose you can glue/cover it with leather if fancy desired?
There should be sound-insulation padding between the fibre-shell and the steel 'chassis' centre box.
Users browsing this forum: GLB and 26 guests
