Lotus Elan
S4 Gear lever gaiter locating plate
PostPost by: Philturn » Sat May 13, 2023 9:31 am
Am I right in thinking that the gearlever gaiter locates in a flat metal plate, that is in turn, screwed to the grp gearbox tunnel?
If so, does anyone know the dimensions of this plate?
Thank you, Phil.
Philturn
New-tral
PostPost by: RichardHawkins » Sat May 13, 2023 6:57 pm
Seniorchristo posted Feb 20 2018 with the dimensions you are after under body chassis frame, I think Phil Harrison has also posted dimensions, but cannot find his post.
Good luck with the search,
Richard Hawkins
RichardHawkins
PostPost by: pharriso » Sat May 13, 2023 8:16 pm
Phil Harrison
1972 Elan Sprint 0260K
PostPost by: pereirac » Mon May 22, 2023 5:59 pm
I don't remember mine ever being screwed in, although the holes are there. It just sits nicely between the transmission tunnel and the plastic tunnel cover.. Makes changing the gaiter every few years when it splits nice and easy..
Carl
72 Elan Sprint
87 Excel SE
97 Alpina B10
http://www.lotuselan.co.uk
pereirac
PostPost by: Zlinster » Mon May 22, 2023 10:26 pm
I fitted mine today. Really worthwhile. Entire operation took half an hour. Riveted in place and silicon sealed. I realised that fitting the gaiter prior to installation was going to save a fiddly job later. The console simply sits over the plate and gaiter. The console no longer moved with each gear change.
Both cheap and satisfying.
Zlinster
First Gear
First Gear
Users browsing this forum: GLB and 38 guests
