Lotus Elan
1966 Elan S2
PostPost by: khamai » Tue Nov 29, 2022 4:47 am
Stack_ElanS2_5 (Medium).jpg and
Congratulations on the new project car!
Happy to see it go to a great home.
It's a big project, early-ish S2s are precious and deserve to be resurrected.
Sounds like you're planning to go with KOs with steel wheels. Should you decide to go with the Panasports, you'll find a bit of background info here - https://www.gglotus.org/ggtech/elan-pan ... anwhls.htm
Kiyoshi
Life is more fun behind the wheel of a Lotus!
www.gglotus.org
www.gglotus.org/blog
khamai
PostPost by: Ianashdown » Tue Nov 29, 2022 5:09 am
I’ve not decided on one or the other. A set of steel wheels came up locally so I thought I’d pick them up to have both options.
I think the wheels alone set the appearance in very different ways, and for the cost of a second set of tires I have both options!
Just the first of many choices to be made, only this one I elected to not make a decision!
Ian
SoCal
Ianashdown
PostPost by: Pabarlow » Tue Nov 29, 2022 5:38 am
I have a spare cam cover with no less than three similar vents added to it. I have removed them and will be welding up the holes.
Reasonable looking base for your total restoration, and well worth rescuing (well, other than the blood, sweat, tears and cash outlay, but that's standard practice).
Peter
Current: Elan S3 FHC Airflow; Europa Twincam; Jaguar XJ12, Miata NB.
YouTube: GigPete
Pabarlow
New-tral
PostPost by: Ianashdown » Tue Nov 29, 2022 6:44 am
Pabarlow wrote:I have a spare cam cover with no less than three similar vents added to it. I have removed them and will be welding up the holes.
Thank you!
I absolutely think it’s a great candidate for rescue. Blood, sweat and tears? That’s a given, but that’s almost the point!
Ian
SoCal
Ianashdown
PostPost by: 661 » Tue Nov 29, 2022 1:04 pm
That will be the star of the show if you take it as is to a car meet.
Lovely project ahead of you.
It is possible to do most things yourself, or at least the preparatory work
Graeme
S4 SE
S2 GTS
Caterham 420R
Sold - Peterson JPS Exige
PostPost by: Ianashdown » Tue Nov 29, 2022 3:22 pm
661 wrote:That will be the star of the show if you take it as is to a car meet.
It’ll be fun to take the car ‘as-is’ to my local Cars and Coffee. I’m a little sad that most of the nuts and mouse crap will have blown out on it way to me, 400 miles on an open trailer, but I think they’ll get the idea.
I plan to do almost everything myself, but using available services such as dry ice blasting for the body, sand blasting for the chassis, welding if needed, all the specialized engine machining, I’ll build the engine but it’ll be fine tuned on a dyno by an ex-Cosworth guy, I’ll also be getting help from a friend who’s painted Pebble Beach cars in the past. There are other specialists I’ll need to use, but overall I’ll be doing all that I can.
The therapy is in the work!
Ian
SoCal
Ianashdown
PostPost by: alan.barker » Tue Nov 29, 2022 5:47 pm
Hi Ian,
What a fantastic project.
Well done and keep posting
PostPost by: Quart Meg Miles » Tue Nov 29, 2022 11:38 pm
Certainly a good project in store, Ian, and it would be great to keep it standard, but your other post suggests you hope to tune it fairly heavily.
On the wheels, you can't easily swap from bolt-ons to knock-ons as the hubs are different and I believe that includes the stub axles. So you would need different uprights and probably calipers too as the pads may wear differently.
The red cam covers used to be for racing engines but I did notice the possible patch of standard blue which isn't a terribly dark shade.
Best of luck with it.
Meg
Quart Meg Miles
PostPost by: Emma-Knight » Wed Nov 30, 2022 12:09 am
I found dry ice blasting may cause micro crackels in the gel coat surface.
I then tried soda blasting- which worked fine.
Anna, 66 S2
1965 S2
Emma-Knight
PostPost by: Ianashdown » Wed Nov 30, 2022 12:42 am
Quart Meg Miles wrote:Certainly a good project in store, Ian, and it would be great to keep it standard, but your other post suggests you hope to tune it fairly heavily.
Yes I have the knock-off hubs too and the car will be built that way. The only question is steel knock-off’s or Panasport knock-off’s.
I think in the end if all the numbers match I will have to stay authentic. A few invisible bolt-on improvements perhaps.
There is some blue! I know someone who has had the original blue specially color matched. I’ll go with that I’m sure.
Ian
Ianashdown
PostPost by: Ianashdown » Wed Nov 30, 2022 12:45 am
Emma-Knight wrote:I found dry ice blasting may cause micro crackels in the gel coat surface.
Anna, 66 S2
Really? Dry Ice is supposed to be the gentle process.
Soda seems to be much more available. Maybe even DIY . . .
Thanks for the feedback,
Ian
Ianashdown
PostPost by: StressCraxx » Wed Nov 30, 2022 2:05 am
Ian, if you need original steel K/O wheels, let me know. I may have a set or partial set that are usable.
StressCraxx
PostPost by: Ianashdown » Wed Nov 30, 2022 3:25 am
I just bought a set from a San Diego Elan driver!
So now I’ll have choice between the standard steel KO wheels and these
CD31B130-0689-4CDB-80A6-21F9DD693A4F.jpeg and
That are part of my purchase.
Ian
Ianashdown
PostPost by: khamai » Wed Nov 30, 2022 5:02 am
I was pretty excited to see the Panasport wheels. It was the 1st time I'd seen a set in the anthracite color. The silver and gold are the most popular.
Kiyoshi
www.gglotus.org
khamai
PostPost by: Ianashdown » Wed Nov 30, 2022 5:11 am
It is unusual, but I think I like it. It’s a classy look I think!
Ian
Ianashdown
PreviousNext
