has this car caught fire?
If you're referring to the bits of resin soaked glass hairs, like in pic 6, that aren't stuck down to the shell its normal. Having said that, most of what you show appears to be repairs, poorly done. Hard to tell if it is fire or accident that caused the damage.
Scott
45/9011
Hawkestone, On, Ca
45/9011
Hawkestone, On, Ca
- snowyelan
snowyelan wrote:If you're referring to the bits of resin soaked glass hairs, like in pic 6, that aren't stuck down to the shell its normal. Having said that, most of what you show appears to be repairs, poorly done. Hard to tell if it is fire or accident that caused the damage.
+1
It is difficult to see, but it looks as if part the front nearside wing may have been grafted on. With this and the patched damage to the interior panels, I would have guessed the car was subject to a front nearside impact. Pretty typical given the car's sporty nature. My Sprint has a new front which joins just in front of the wing repeaters which has not been fitted very well. Given the chassis (frame) was replace at the same time (early 80s) I suspect the car had a prang - it is very possible your car had the same fate.
If there had been a fire (which is always possible) it is usually over on the carburettor side of the engine.
32 Standard 12
Various modern stuff
32 Standard 12
- Andy8421
It just looks like a very bad repair. It needs a proper repair by someone who knows what they’re doing and it doesn’t really matter whether it was accident or fire. In some ways fire would be better, as accident damage can appear in other unexpected areas.
Elan +2
Elise mk 1
Elise mk 1
- Donels
Users browsing this forum: Ray419G and 25 guests
