1972 Elan Sprint - engine removal
Hello, I'm sure this topic has been covered numerous times, so advice from someone who has done this before would be welcome, to save me trawling through thousands of earlier posts. Although owning my Sprint for 46 years, have always left engine removal to a garage, though have managed to handle all other issues OK.
My question relates to access to the 14mm bolts on the bell housing to engine. What tools are needed to as none of my extensive collection will do the job (or am I missing something here)?The Lotus workshop manual has a sense of humour and just says "Fit a sling and support the engine on suitable tackle (done). Unscrew the lower clutch housing bolts and remove the cover (done). Unscrew the clutch housing to engine bolts (*******!). Disconnect the engine mountings.....Suitably support the gearbox. Pull the engine forward of the mainshaft of the gearbox and lift up and out from the engine compartment."
If only it was that simple!
David B, North Wales.
- DavidMB
DavidMB wrote:My question relates to access to the 14mm bolts on the bell housing to engine. What tools are needed to as none of my extensive collection will do the job (or am I missing something here)?
One thing for sure... the bolts aren't 14mm All the fasteners on the elan (apart from those on the Weber Carbs) are imperial.
Regular spanners & lots of patience are required... removing the rear carburetor makes access easier & you should probably remove both anyway to avoid damage when lifting the engine out.
Phil Harrison
1972 Elan Sprint 0260K
pharriso - Coveted Fifth Gear
Don't just remove rear Carb, always remove both Carbs with backing plate.
Then you can access Bellhousing bolts + Fuel line + Engine Mount.
Have fun
Have fun
- alan.barker
Thanks for the replies. I forgot to mention that all bits and pieces and engine connections have been disconnected, including the carbs and exhaust manifolds. I can see all the bolts to be removed, so I'll just have to be patient, I guess. I'm also aware, after 46 years of ownership, that nuts and bolts are Imperial!
Per ardua ad engine removal....
- DavidMB
Yes,
My Granfather was in the Royal Flying Corps.
- alan.barker
The bolts into the bell housing from the front of the car generally need a couple of long extensions and a flex joint on a socket. The two that go into the block from the back need a ring or open ended spanner and potentially dropping the nose of the engine a little to more easily get at them.
