Elan Parts List - Excel file
There are a lot of online sources for the parts list, but there is nothing like have it also off-line on the computer.
I scanned all the pages and OCR'd them. Then I put them into an Excel and corrected the errors (mostly text/data misplaced on the page).
I re-arranged some data on the page into new columns and prepared them for inserting the data into a database (more on that later).
There is some more work to do, but I think it is quite nice already.
So, here it is, the first part (of 3).
Please feel free to make comments, corrections, suggestions.
Do not expect part 2 for tomorrow ... less so, if there are good suggestions for a better version of it
- Attachments
- Lotus Elan Parts list (1971) part 1 of 3 - AA-BN.xls
- (1.06 MiB) Downloaded 470 times
1964 S1 (at paint shop)
1967 S3 DHC
1969 S4 FHC (at BB's home)
1967 S3 DHC
- gherlt
Well done and thank you for your efforts.
Visit www.lotuselansprint.com
trw99 - Coveted Fifth Gear
Impressive. Thank you. Take the rest of the day Off.
Charlie Warner
Fatto Gatto Racing
Fatto Gatto Racing
fattogatto - Third Gear
Wow that takes some doing, Brill job.
Someone on here was talking about using a list like this to crate a definitive bolting list! they will get a real leg up once you have finished the second half.
- TrevorJones
TrevorJones wrote:Wow that takes some doing, Brill job.
And if we really want we can do this - https://test.elanregistry.org/app/list_parts.php
I imported the sheet into a DB which you can search. I also based together a count of things called BOLTS. We could even convert the PN to a description.
And yes, I had nothing to do this afternoon
Unibrain - Third Gear
That pages does a good job of locking up the browser on my phone. I suspect that's down to the page size and probably works on on a desktop.
I am just (hopefully) finishing up a spreadsheet that can decode the bolt/screw/nuts/washer part codes. Which I was going to upload here.
Not sure if that's what you're referring to but having something like that in a web page would be useful. Probably more useful that a spread sheet
Unibrain wrote:We could even convert the PN to a description.
- mbell
mbell wrote:.
The spreadsheet is the preparation for a database import.
1967 S3 DHC
1967 S3 DHC
- gherlt
I get that. I am talking about being able to decode the part numbers for bolts etc in to a human readable text form.
I am not sure if that is included in the page or not ( as my phone can't cope with the pages).
- mbell
mbell wrote:I get that. I am talking about being able to decode the part numbers for bolts etc in to a human readable text form.
It was just a quick example of what is possible. I didn’t do the translation
FYI, https://lotuselan.net/wiki/Intro_-_Stan ... ber_Coding
Please find attached newest version
I made a few error corrections, changes (thanks for the tips) and three new columns:
- moved text out of "change point information" to comments, when NOT related to "change point"
e.g. "Coupe only", "Failsafe"
- Added Columns Chassis from/upto: numerical values of change point text
"ChassisFrom" the number after any "From" indication,
"ChassisUpto" the number after any "Upto" indication,
some text lines changed to simplify the extraction function
- Added column "HandedPart", displays "LHD" or "RHD", if the "+" is present in the Steering LH / RH columns
Let more suggestions come in !
- Attachments
- (1.15 MiB) Downloaded 229 times
1967 S3 DHC
1967 S3 DHC
- gherlt
Hello,
I finished with part II & III, and a few corrections more on part I.
I will unite the three spreadsheets into one signle file tomorrow, if Excel holds up ...
I would like to ask for volunteers to review the files, as I go over and over I always find some small errors.
I need to correct the columns "Chassis from"/"Chassis from" as there are also engine change points.
I would also like to add a "car" column, as this is for the two seater but is expandable to the +2 (and should be done). If we get this right, other Lotus cars parts lists could be added.
Any other suggestions ?
Later this evening I will try to write down my vision for the parts database ...
- Attachments
- Lotus Elan Parts list (1971) part 3 of 3 - FB-TA.xls
- (948 KiB) Downloaded 226 times
- Lotus Elan Parts list (1971) part 2 of 3 - BO-FA.xls
- (1.03 MiB) Downloaded 256 times
- (1.06 MiB) Downloaded 241 times
1967 S3 DHC
1967 S3 DHC
- gherlt
Please find attached the unified Excel-file.
1967 S3 DHC
1967 S3 DHC
- gherlt
Yes, indeed.
1967 S3 DHC
1967 S3 DHC
- gherlt
XLS is too big (3MB), newer file formats XLSX and ODS are not allowed. ZIP neither.
So .... github:
https://github.com/gherlt/Lotus-Elan-Pa ... st%20(1971)%20AA-TA%20.xls
There is a download button on the right.
So .... github:
1967 S3 DHC
1967 S3 DHC
- gherlt
Users browsing this forum: crannyr and 34 guests
