Can you identify this?
You would be correct....... usually paired with an aftermarket electric fuel pump (https://www.advancedautomotives.co.uk/s ... 2304-p.asp)
I have a slightly different version regulator but i run mine on 2psi!! (yours looks like it's set to 4.5psi), that said i have Webers so couldn't say for sure if they prefer a different pressure.
Grizzly - Coveted Fifth Gear
I have the same regulator feeding my stromberg carbs, purchased from Burton Power over 15 years ago. I usually set the pressure for 2psi.
Dave Chapman.
Dave Chapman.
- david.g.chapman
Looks a bit like mine and with weber I have it at 1, seems to work just fine
- Concrete-crusher
