My first elan
Hi everyone I’ve just bought my first elan, I traded in my gorgeous R300 Superlight for the series 4 from UK Sports Cars this one https://www.uksportscars.com/view/lotus ... SIXmFovcK0 the question who do you considered the best company for insurance
Regards phil
Regards phil
- philbirch
Hi Phil.
I use Routen Chaplin, the manager/organiser is a Lotus Elan fan.
Just a suggestion, are you in a car club. Club lotus cheshire branch have meetings once a month and have an active social calendar.
Also lancs/Merseyside hold meetings near Preston which may be useful. Several Elans there including mine.
Your car looks beautiful, maybe I will see it sometime.
Eric in Burnley
1967 S3SE DHC
Eric in Burnley
1967 S3SE DHC
- ericbushby
Congratulations Phil, you will enjoy it. I am curious, what is the blue hose/wire that comes from near the windshield washer bottle & over the engine down between the carbs?
Keith Marshall
- saildrive2001
Phil,
Check out Hagerty, I'm insured with Hiscox via them for both my Elans; Hagerty are great folks, real enthusiasts.
Pete.
http://www.petetaylor.org.uk
Pete.
saildrive2001 wrote:Congratulations Phil, you will enjoy it. I am curious, what is the blue hose/wire that comes from near the windshield washer bottle & over the engine down between the carbs?
This sounds mad but it looks like the coil might have been relocated ? Maybe the washer pump is now below the passenger side bonnet catch.
Nice car nonetheless
'72 Sprint
'72 Sprint
- richardcox_lotus
Phil,
Car looks great. Common mistake by paint shops not used to Elans is to miss painting the bottom of the sill black. If you have a look at pictures of Elans on the web, most have been correctly painted, but a number have been missed. There have been suggestions that the Elan looks better without, I personally prefer the black line along the bottom.
Its not a long job with some masking and an aerosol (or brush) if you are aiming for originality.
Welcome to Elan ownership.
32 Standard 12
Various modern stuff
32 Standard 12
- Andy8421
Thanks for all the replies, the cable around the carbs is a Heath Robinson invention to hold the accelerator cable in place, I’m sure there’s something better than this, that’s if it’s really necessary, my intentions are to gradually improve the car over time The position of the coil is quite possibly because the car has electronic ignition, there’s a drawing in the box file that came with the car, this details the wiring of the Lucas system, maybe I should carry a set of points and condenser for emergencies.i know the car quite original and there are areas that can be improved if you could point these area out I would appreciate that
Thanks again Phil
Thanks again Phil
- philbirch
philbirch wrote:i know the car quite original and there are areas that can be improved if you could point these area out I would appreciate that Phil
No criticism intended as the car looks really nice although it does appear to have an S3 boot handle. I have seen a very late S3 with a S4 boot handle but I have not seen the S4 with S3 fittings but after all its a Lotus and as you will find out nothing is written in stone
Do not change the boot handle, my car came with the same handle & they are no longer available.
Keith Marshall
- saildrive2001
Phil,
Congratulations! That is a very smart looking Elan. You will not be disappointed. We would al lbe proud to drive that vehicle.
All the best,
Frank
All the best,
Frank
Famous Frank
67 Elan Coupe
66 Elan S2 SE
65 Elan S2
65 Elan 26R
69 S2 Europa
06 Elise
67 Barracuda
67 Elan Coupe
66 Elan S2 SE
65 Elan S2
65 Elan 26R
69 S2 Europa
06 Elise
67 Barracuda
Famous Frank - Fourth Gear
philbirch wrote:
'I know the car [is] quite original and there are areas that can be improved if you could point these area out I would appreciate that'
One of your priorities should be to fit the secondary door seals Phil, otherwise you are not going to be able to wash the car without getting the carpets wet. Obviously you are not going to take it out in the rain I do not know what sort of deal you did with KSC, but maybe they should fit them, as they are rather important.
Enjoy Elan ownership.
Leslie
Leslie
- 512BB
