Weight of Elan chassis back in 1962?
Any documented evidence of what the first production Elan chassis weight was? I've looked all over the place and can't find it.
Thanks.
Thanks.
Pete.
http://www.petetaylor.org.uk
Pete.
Frogelan wrote:Very roughly speaking it is about 40 kg...
Thanks.
Pete.
Pete.
(Weight in 1962) = (Weight now) - (weight of oil coating) - (weight of rust)
But seriously, the only change to the chassis from '62 to 75 was the front tower angle? So all chassis' weigh a similar amount - apart from the 26R which weighs more due to additions & re-inforcements.
Phil Harrison
1972 Elan Sprint 0260K
pharriso - Coveted Fifth Gear
Phil, you got your math wrong by ADDING weight with rust......you should be SUBTRACKING weight due to the loss of metal !!!!!
TED
- tedtaylor
I cannot put a figure on the question, but I bought my replacement chassis in 1979 at age 30, I could just carry it under one arm, so 40kg for a fit young man seems about right.
Richard Hawkins
Richard Hawkins
- RichardHawkins
Ted- There's no loss of metal unless the rust flakes off. All the base metal is still there as part of the oxide and protected the oil.
Bud
1970 +2S Fed 0053N
1970 +2S Fed 0053N
- Bud English
Bud English wrote:Ted- There's no loss of metal unless the rust flakes off. All the base metal is still there as part of the oxide and protected the oil.
In fact there is an increase in weight due to the oxygen consumed to make the rust
- stevebroad
tedtaylor wrote:Phil, you got your math wrong by ADDING weight with rust......you should be SUBTRACKING weight due to the loss of metal !!!!!
Since Chapman was involved, it is "add lightness"
- ivorbadger2
I must have missed science class where they discussed oxide, oxygen, rust, weight ratio, etc.
I'm just going by some of the rusted "away" frames I've seen over the years where sections of metal frame are consumed, gone, disappeared, missing, or otherwise "rusted away", so it would have to weigh less.
TED
- tedtaylor
Plus, how heavy are the tin worms?
Rob Walker
26-4889
50-0315N
1964 Sabra GT
1954 Nash Healey LeMans Coupe
26-4889
50-0315N
1964 Sabra GT
- prezoom
seen here : a bit shy of 100 pounds
lotus-chassis-f36/spyder-chassis-lotus-chassis-weight-t36119.html
S4SE 36/8198
nmauduit - Coveted Fifth Gear
Users browsing this forum: lotusfan and 35 guests
