Correct clear coat for dash
Back to the project. I had a woodwork guy put new veneer on my dash. He did a fine job on the veneer and stain but put only one very thin coat of clear. Reading bits and pieces from the forum, can I apply several coats of a "thicker" polyurethane clear until I get the correct depth that I want? Of course there will be fine sanding and polishing. I went down to the local home improvement store and the Minwax brand clear urethane was like water. Can someone recommend the correct brand and type of clear for me to use?? California based.
Mike Summers
Mike Summers
- bluesbrother30
Traditionally a varnish finish is built up by many coats; start with a thin diluted coat building up to the final undiluted coat.
But today an epoxy is used where the surface is flooded with the coating material.
Lots of info on the net.
If you have a DHC then not all finishes are for exterior use. Look at ships varnish.
Ron.
Ron.
- Craven
I don't know if this classifies as correct, but for what its worth i have moved away from the reduced to unreduced varnish routine to using a base of clear epoxy (West 205 with 207 special clear harder ) that is blocked flat followed by multiple coats of automotive high solids clear urethane - there is no amber tint , so your base color is what comes through. The finish is also hard pretty much from the get go vs poly of spar varnish that takes a while..
George
George
- cabc26b
I posted about 8 years ago regarding how I refinished my dash. It's been in for 13 years now and has no cracking whatsoever.
http://www.lotuselan.net/forums/lotus-chassis-f36/dash-refinishing-t19702.html
Gary
'71 Sprint FHC
Miami, Florida
Gary
'71 Sprint FHC
Miami, Florida
archigator - Fourth Gear
Users browsing this forum: No registered users and 44 guests
